Pot Joint Removal
Posted 30 January 2010 - 04:37 PM
So i've had to resort to starting another topic.
After getting one side out i can't get the other to budge.
It is the passenger side that is causing me touble.
Now i have tried.
-Levering against bolt on diff casing with a crowbar, whilst levering getting my dad to hit the joint also hitting the end of the bar.
-Bolster chisel (which actually popped the drivers side out easily).
-Pot joint removal tool.
I have also tried the tool with a bit of packing to make it push the joint out further.
After over a week of trying i've run out of ideas.
Any words of wisdom would be greatly appreciated.
Tim
Posted 30 January 2010 - 05:02 PM
You're try to compress the split ring retainer so maybe a bit of all round hammer attention will help to free it up in it's groove?
If the pot is shot (I is a poet!
Drilling the hole may be even harder though.
Posted 30 January 2010 - 05:20 PM
I was pretty shocked myself at it being so difficult the drivers side just popped of nicely.
Tried a bit of hammer action maybe some extensive working tomorrow will solve it.
I'm getting worried that maybe the previous owner used a square clip and with the flat edge in the pot it has no tendancy to compress.
The pot is getting replaced but I don't think i've got anything that will man enough to drill through it.
And i'd be a bit worried about damaging the output shaft.
Been trying to think of some way to use a slide hammer but can't think of anything to grip too.
Getting increasingly worried that all of this can't be too good for the casing.
Posted 30 January 2010 - 05:26 PM
Posted 30 January 2010 - 05:35 PM
Should have said, I have already removed the boot and the innards with the driveshaft.
The engine is still in the car if i can't find any solution it's going to have to come out i guess.
Posted 30 January 2010 - 05:57 PM
Posted 30 January 2010 - 06:13 PM
Lots of hitting the joint seems to be order the day.
Any other techniques to try tomorrow will be greatly appreciated.
Thank you to all that have posted so far.
Posted 30 January 2010 - 06:20 PM
Also try and tap the outside of the pot whilst turning it round to see if the clip will centralise on the shaft.
Posted 30 January 2010 - 06:35 PM
Although i tried tapping it out turn, repeat. as i was tapping outwards i guess it holds the clip off to one side.
Thanks tomorrow is looking slightly more hopeful.
Posted 30 January 2010 - 07:30 PM
Posted 30 January 2010 - 07:56 PM
I'm really hoping these tips work.
Got so many other things i need to get done tomorrow aswell.
Posted 31 January 2010 - 12:18 PM
It makes no sense that it can be this tight and i can only think that the wrong type of clip has been used on the output shaft.
Something definitely isn't right as when i put the removal tool in there is no resistance at all holding it until it's way past resting on the bolt i've made a shim to help this but it's still not helped. Also i have about 1/16" to 1/8" of play back and forth.
Any more ideas?
Posted 31 January 2010 - 12:20 PM
Posted 31 January 2010 - 01:46 PM
Thought that would be the answer.
Just have to keep trying.
