Removing Crankshaft Pulley
6 replies to this topic
#1 Jacques124
Jacques124
  • 169 posts
Posted 31 January 2010 - 04:16 PM
hi all im trying to remove the nut off the crankshaft pulley but i cant move it at all (i was literally jumping on it to undo it? ive tried everything. i took the starter motor off and jammed the fly wheel to stop the engine from turning. is there something obvious ive missed? thanks Jacques :lol: by the way im trying to take off the timing cover to renew the gasket
Edited by Jacques124, 31 January 2010 - 04:17 PM.
#2 mars red mike
mars red mike
  • 1,500 posts
Posted 31 January 2010 - 04:30 PM
Normally a stout screwdriver in the flywheel teeth and a big breaker bar and socket on the pulley nut does the trick. I take it you have knocked the tab washer back?
#3 Jacques124
Jacques124
  • 169 posts
Posted 31 January 2010 - 04:42 PM
yeah i have but its not moving an inch
#4 mars red mike
mars red mike
  • 1,500 posts
Posted 31 January 2010 - 04:50 PM
Maybe you could try drowning the nut in penetrating spray and leaving it to soak overnight then try again tomorrow. Unless you have already done that.
#5 orcadian
orcadian
  • 203 posts
Hi,
You are doing everything right - I use a short piece of 3mm wall steel tube slit in half (so it's a kind of letter C) in the flywheel teeth to spread the load a bit when jamming the flywheel. It's a normal right hand thread on the bolt (anticlock to undo), but the only other extra is that I give the end of the long bar a good whack with a 4 pound Rawhide mallet once it's loaded, to shock it loose. I assume you are also replacing the seal in the cover as well as the gasket. I always put the pulley back through the seal hole and onto the crank before I tighten any of the small bolts to nip the gasket - it centralises everything so the seal is not strained.
#6 lrostoke
lrostoke
  • 6,923 posts
Posted 31 January 2010 - 05:23 PM
Don't try this at home kids.. But it does work
If the engine is in the car and the engine runs.
Put a socket on the crank bolt, use a breaker bar or t bar and turn socket clockwise so the bar is tight against something solid.
disconnect the coil. Then give the ignition key a flick so the starter trys to turn the engine.
Because the socket can't move the force of the engine undoes the bolt.
I've used this method on mini's and Landrovers works a treat.
Although I've now got a compressor and impact gun so don't need use this method anymore :lol:
Edited by lrostoke, 31 January 2010 - 05:24 PM.
#7 Jacques124
Jacques124
  • 169 posts
Posted 31 January 2010 - 05:39 PM
its to late now so will be trying a various method mentioned above :lol: thanks.
