Rear Wheel Spacers
Posted 01 February 2010 - 12:53 PM
I have tried a search on this but not found anything that answers my question really
When I first bought my mini it had a set of spacers on the rear that made the wheels sit nice and flush with the edge of the rear arches, I thought it looked pretty cool as it matched the front - I took it to a Mini specialist to have the radius arms changed as one was stuck fast and couldn't get it off - He advised to get rid of the spacers as they put unecassary strain and premature wear on the radius arms and rear suspension. Is this the case or can rear spacers be fitted with no real negative effect? Cheers for reading
Posted 01 February 2010 - 01:17 PM
Sisters got spaced drums with 1" spacers as well running 12" rims.
Had this setup for 3 yrs covered probably 30,000 miles radius arms and bearings all fine.
Posted 01 February 2010 - 01:38 PM
Posted 01 February 2010 - 02:48 PM
Thanks guys, i'll guess i'll buy some more, mind you have no idea what size they were! If I remember correctly they seemed quite wide!Rover fitted spacers. He might have a bit of an argument if you were heavily offsetting the wheels but with 175/50/13's you will just be restoring the clearance between the radius arm & tyre on the inside.
Posted 01 February 2010 - 03:01 PM
Posted 01 February 2010 - 03:23 PM
So by that do you mean I have to buy new studs? I think the ones that were on there were screwed into the back of the spacers with threads facing out to be then screwed into the hubs, and then the wheels fixed onto the studs, does that make sense??!They are probably genuine Rover ones as the holes on most others are too big to get stuck, but all you should need to do is knock the wheel studs through in to the hub. 3/8" or 10mm should do it. Be sure the studs are long enough if they were swapped.
Edited by biggles1293, 01 February 2010 - 03:24 PM.
Posted 01 February 2010 - 03:34 PM
Posted 01 February 2010 - 03:52 PM
Thanks Ethel you have been most helpful!It does, bit of a nasty botch imho, Minispares do a set of extra long studs and spacers in various widths. Don't go OTT, perhaps 1/2 inch at most, there's already an inch in the brake drums.
Posted 01 February 2010 - 05:18 PM
Posted 01 February 2010 - 05:45 PM
Posted 01 February 2010 - 05:49 PM
Posted 02 February 2010 - 01:39 PM
Excuse my ignorance here, but what is the difference between fitting them for the reason of clearance and the reason of having the wheels flush with the arches? If fitting them to get the wheels flush puts strain on the bearings and hub and radius arms, would it not do the same for the purpose of gaining clearance too?if you fit spacers to the hub for clearance thats fine (tyres to shocks ETC) but fitting them just to make your wheels stick out puts more strain on bearings (hub and radius arms)
Posted 02 February 2010 - 05:06 PM
Posted 03 February 2010 - 10:16 AM
Ah ha! You see, I knew there would be a simple explanation, thanks very much, it's nice to get a straight answer from someone with more knowledge on this subject than myself that isn't sarcastic, much appreciated!if it's for clearance your not pushing the wheel out your just making up for the wrong off set on the wheels
