Which Type Of Coil Do I Need?
6 replies to this topic
#1 mcaville
mcaville
  • 144 posts
Posted 02 February 2010 - 12:09 PM
I have a 1994 Rover Sprite that has been rebored to 1293. I am planning on overhauling the ignition system - new coil, leads, dizzy cap, rotor arm, plugs - but am unsure which type of coil i would need. I'd like to get an uprated one, but it seems that their are different types depending on what type of ignition system your car uses. I'm pretty sure that i don't have a condenser, and i know that i needed an ignition module replacing earlier this year (hope this gives some clues). Oh yeah, there are no ECU's or anything like that involved :goaway:. Any advice would be much appreciated.
#2 Cooperman
  • 23,294 posts
Posted 02 February 2010 - 12:21 PM
The quality of current available coils has been a bit of an issue for some time.
The ideal coil used to be a 'Lucas Sports 12V', but I had a couple over the last 2 years which have failed quite quickly frm new. In the end I went to the local motor factors and bought a cheap standard 12v one off-the-shelf and it seems fine.
There is an American comnpany called 'Pertronics'(?) who make a ceramic-filled coil which is suppposed to be the DB's, but they are very expensive, like £65+ each.
On one of my Minis, which still has a Lucas Sports coil, I carry a spare with me, just in case.
#3 Twincam
Twincam
  • 1,742 posts
  • Local Club: SMAG
Posted 02 February 2010 - 12:54 PM
The part number for the Lucas Sports Coil is DLB105 - I've got a spare too (never know)
#4 mcaville
mcaville
  • 144 posts
Posted 02 February 2010 - 01:54 PM
I looked at one place that was selling the DLB105 but it said that it was for pre 1986 minis. This is what has lead to my confusion. Some are for with and without ballast (whatever that means).
So will the Lucas sports coil work with any mini?
#5 WiredbyWilson
WiredbyWilson
    WiredByWilson
  • 5,004 posts
  • Local Club: WiredByWilson
Posted 02 February 2010 - 03:45 PM
As you are running electronic ignition you will only need a normal coil - a sports coil won't improve anything.
Spend the money on better leads & plugs along with a new cap and rotor. I only run a std 12v coil with my aldon and tuned 1330.
Edited by Wilson1330, 02 February 2010 - 03:45 PM.
#6 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 02 February 2010 - 04:07 PM
GCL143
Edited by Guess-Works.com, 02 February 2010 - 04:13 PM.
#7 Twincam
Twincam
  • 1,742 posts
  • Local Club: SMAG
Posted 03 February 2010 - 07:28 PM
From Haynes:
Type:
848CC and 1098CC engines - Lucas LA12
998CC engines
- Pre 1982 models - Lucas LA12
- 1982 models - AC Delco 9977230 or Ducellier 520035A
- 1983 models on - GCL 144
1275CC engines
- Pre 1990 models except Cooper S MK 3 and later 1275GT - Lucas LA12
- Cooper S Mk 3 - Lucas HA12
- 1275GT, 1978 on - Lucas 15C6
- 1990 models on - GCL143
