1800 mini
8 replies to this topic
#1 aussie78leyland
aussie78leyland
    Starting My Mini Up
  • 1 posts
Posted 27 October 2005 - 08:19 AM
i just bought a 78 leyland mini and i have heard a rummer that a austin 1800 engine will bolt into a mini with minimal modification. i was wondering if any one had insight in to this topic.
#2 Jammy
Jammy
  • 25,397 posts
Posted 27 October 2005 - 09:00 AM
I believe that is an O series engine?! I think that requires quite a lot of modding to get in, and if your taking all the trouble to do that you may as well put in the newer K series (from a metro, rover, lotus elise...), a vaux engine or Vtec.
#3 m1n1
m1n1
  • 768 posts
  • Local Club: I'm unsociable
Posted 27 October 2005 - 01:16 PM
I thought O - series units were 80's engines, fitted to maestros/montegos' etc...
When i worked at Big M motor factors many years ago these was a guy there who used to go on and on about his mini which he fitted with an old 1800cc maxi engine. I think thats B - series.. but i don't know. anyway he used to brag about how fast it was.. etc. it did fit, but i remember him saying he had to work on the subframe and the inner wings a little :lol:
#4 Sprocket
Sprocket
    Great on Injection faults
  • 7,266 posts
Posted 27 October 2005 - 09:35 PM
The B serries will fit but will need an amount of engineering to make it work. I believe the cars used in the film Italian job, the parts where they drive down the stairs had the B series engines fitted as the transmission was a little more robust. I seem to remeber that they were the 1600 veriety though.
Like others have said, why bother with an old B series. Just fit a 2.5 litre V6 Ecotec from a vauxhall like others have done http://www.16vminicl...orums/index.php :sick:
#5 jack_marshall
jack_marshall
  • 2,540 posts
Posted 27 October 2005 - 11:18 PM
Im sure the B series engines come from cars like the classic MGA's??
#6 The Matt
The Matt
  • 17,232 posts
  • Name: Matt
Posted 28 October 2005 - 06:36 AM
The old 1750 Maxi engine! It is not an A series engine I don't think, and also is a bit heavier than the old Mini engine.
There was a car in Miniworld about 7 or 8 years ago that had the conversion (a blue and yellow one IIRC).
Bit of a major conversion, I'd go for a more standard jobby meself and drop a VTEC or even Metro turbo engine in if I wanted to go for major power now!
#7 Wil_h
Wil_h
  • 3,244 posts
Posted 28 October 2005 - 07:33 AM
Maxi engines were used as a conversion engine years ago as they had the same engine/gearbox lay-out as the Mini (i.e. box below engine). So it was theoretically an 'easy' swop.
Although I've never done it, I suspect it's no easier to fit than fitting a modern engine. It certinally won't be a bolt-in and drive off conversion.
The other problem is the Maxi engine is it's a big old lump and ends up sitting much further forward than the a-series. This would make the handleling rubbish (loads of understeer).
The Maxi engine is infact an e-series engine with about 90 bhp, so a pretty pointless swop really.
The B-series was only ever an 1800 as far as I know, and was fitted to MGBs, the 'B' being the give away. It was also fitted to Marinas. It was never used as a front-wheel drive engine.
Wil
#8 Sprocket
Sprocket
  • 7,266 posts
Posted 28 October 2005 - 05:39 PM
Wil
http://www.austin-ro...inebseriesf.htm
Now you know different :cheese:
#9 Wil_h
Wil_h
  • 3,244 posts
Posted 28 October 2005 - 10:13 PM
Well well, that'll teach me for being born in the 70s.
I wonder what front wheel drive cars it was used in?
Wil
