Eating 10a Fuses
13 replies to this topic
#1 danie garry
danie garry
    I love BMW minis
  • 2,296 posts
Posted 04 February 2010 - 07:53 PM
seems that my car has decided to keep blowing the 10 amp fuse for the indicator/stereo/brake switch
think its the indicator doin it but is there anything else i should check that could be destroyin my fuses!?
#2 Paul Wiginton
Paul Wiginton
  • 1,585 posts
Posted 04 February 2010 - 08:12 PM
Is it a factory fitted stereo?
Could be a dodgy earth on the rear lights
#3 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 04 February 2010 - 08:31 PM
well if all the indicators are on, and brakes you should be pulling 112watts for the lamps, which is < 10 amp therefore I'd be looking at the stereo... or a direct to earth connection... ( earth leak )
Edited by Guess-Works.com, 04 February 2010 - 08:32 PM.
#4 danie garry
danie garry
    I love BMW minis
  • 2,296 posts
Posted 04 February 2010 - 09:01 PM
its got a stereo that i put in a year ago, i put in a new fuse and the radio worked ok but when i went to indicate left the green light on the dash was dim and then all gone again.
#5 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 04 February 2010 - 09:56 PM
What Mini is it? Which fuse?
#6 shorty
shorty
    Short Guy
  • 3,606 posts
Posted 04 February 2010 - 10:06 PM
try a 15a fuse?
#7 danie garry
danie garry
    I love BMW minis
  • 2,296 posts
Posted 04 February 2010 - 11:04 PM
sorry, its a 96 spi fuse 10 (dan's previous wisdom!!!)
if i put in a 15 amp fuse would that not put too much current onto everything??
#8 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 04 February 2010 - 11:12 PM
No but it might allow too much current to be drawn and start a fire. Uprating (or downrating for that matter) fuses in a circuit that you don't have complete technical details for is very dangerous.
You need to find out what is actually causing the fault. Does it happen every time you use the indicators? Regardless of what else is on or off?
#9 danie garry
danie garry
    I love BMW minis
  • 2,296 posts
Posted 04 February 2010 - 11:18 PM
well the radio was fine til i used the indicator, i think the unit is at fault because the earth came detached a few weeks ago and i noticed that some1 had done a bit of a bodge with the wiring up to the unit. theres been a big puddle for the last week i have to pass to get to college so i'l take a look at that in the mornin
#10 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 04 February 2010 - 11:22 PM
Leave the radio unplugged for a day then and see if everything else works properly.
I've had a quick look at a wiring diagram and as standard fuse 10 is supposed to only run the radio memory. Fuse 9 is supposed to be the radio supply. The problem is that many modern radios use what would normally be thought of as the memory supply, that is to say their permanant supply, as their main source of power and just use the ignition supply as a trigger to turn on and off. Can the radio be turned on without turning the ignition on?
#11 danie garry
danie garry
    I love BMW minis
  • 2,296 posts
Posted 04 February 2010 - 11:25 PM
i'l try that but its as soon as i indicate the fuse goes
its gonna be a long drive home tomorow!!! 100 miles and no radio!!
no the ignition needs to be on for the radio
Edited by danie garry, 04 February 2010 - 11:26 PM.
#12 Frozo
Frozo
    This Man Has Been GIVEN A Mini, Lucky Bugger!
  • 521 posts
Posted 04 February 2010 - 11:26 PM
:D thats a long way lol. you not got a ipod or nothing?
sorry for off-topic
#13 danie garry
danie garry
    I love BMW minis
  • 2,296 posts
Posted 04 February 2010 - 11:28 PM
i'd usually plug the mp3 player into the radio!!!
100 mile home then the same 100 mile back on sunday=oil change every month!!
#14 danie garry
danie garry
    I love BMW minis
  • 2,296 posts
Posted 05 February 2010 - 06:58 PM
all sorted now, some1 had cut the indicator wires and rejoined them with spade connectors and 1 had come out a bit and was touching off something, but its all better now thanks lads
