Braided Oil Filter Feed
11 replies to this topic
#1 screech
screech
  • 3,136 posts
  • Local Club: Bognor rock ya mini & WSMOC
Posted 04 February 2010 - 10:11 PM
Hey guys,
Im thinking of fitting one of these CLICKY
Anyone got one, are they any good. pictures??
cheers
Edited by screech, 04 February 2010 - 10:12 PM.
#2 HARBER07
HARBER07
  • 4,498 posts
  • Local Club: Naaa......
Posted 04 February 2010 - 10:14 PM
Yeah pretty good, if you can justify nearly £30 on a foot of hose!
#3 Dan
Dan
    On Sabbatical
  • 21,354 posts
These are only really worthwhile on 12A engines or possibly racing applications.
#4 Kam
Kam
    Straight to the Point
  • 4,140 posts
  • Local Club: 16vMini club
Posted 04 February 2010 - 10:18 PM
What they are replacing is the troublesome pipe so its always a win win situ. Oil pressure loss is never good! :D
I had the minispares one which is a bit more but :D
#5 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 04 February 2010 - 10:20 PM
Except that on engines earlier than 12A types, the pipe was never a problem!
#6 screech
screech
  • 3,136 posts
Posted 04 February 2010 - 10:31 PM
Iv got a kink in mine, so needs replacing! I honestly have no idea what a 12A engine is, all i know is i think the one i posted up is the one for mine, with the big banjo bolt.
cheers
#7 Kam
Kam
  • 4,140 posts
Posted 04 February 2010 - 10:32 PM
I dont know which engine he's got Dan? The link picture has a banjo on one end but I'm sure the 12A's don't?
#8 Kam
Kam
  • 4,140 posts
Posted 04 February 2010 - 10:34 PM
cheers
Ahh beat me to it, fair enough, I thought you just put up a random picture of a braided feed pipe.
#9 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 04 February 2010 - 10:37 PM
If you want to spend the money then by all means buy it. A good second hand banjo pipe will be fine though, the banjo type pipe was always reliable. 12A engines (the engine number starts 12A) don't use a banjo bolt to connect the pipe to the engine. They use a plain ended olive sealed pipe that is known to pop out of the engine every now and then.
#10 liirge
liirge
  • 4,097 posts
  • Local Club: EDMC AND MMC
Posted 04 February 2010 - 10:55 PM
what kind of DIY solutions are there for this?
like a couple of fittings and hose? i imagine the wrong application for jubilee clips.
Edited by liirge, 04 February 2010 - 11:00 PM.
#11 Pooky
Pooky
  • 5,691 posts
Posted 05 February 2010 - 07:18 AM
I was considering buying one of these for my small bore. The reason being that I could never get the banjo end to seal properly. The edge of the circular bit on the edge of the pipe seemed to foul the block :(
Could I just use two or more copper washers?
#12 Alexandre34
Alexandre34
  • 55 posts
  • Local Club: Les Mini Caisses du Sud
Posted 05 February 2010 - 10:00 AM
Hi !
I have fitted one like this just before going to the IMM last summer on my Spi Mini, because the engine is a 12A and because I had the problem with the plain ended olive sealed pipe that was slightly leaking, and as it was known to pop out under arduous conditions I didn't want to travel to the IMM with this risk.
I have fitted this one from Minispares:
Minispares braided oil pipe.
It was quite expensive, but the problem was imediately fixed with no other issue.
