Ht Leads
11 replies to this topic
#1 scoticus
scoticus
  • 1,805 posts
Posted 05 February 2010 - 01:57 PM
Righty, (1977, 998cc)
I need some new HT leads.
But which ones?
Copper or silicone.
I was told the silicone ones were for electronic ignition (which I dont have) is this true?
I have a set of silicone ones on at the moment, they were fine before the strip down, but now they are causing a miss-fire on 2nd cylinder.
#2 scoticus
scoticus
  • 1,805 posts
Posted 05 February 2010 - 02:37 PM
anyone?
#3 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 05 February 2010 - 03:29 PM
std ones, cheap and cheerful...
#4 scoticus
scoticus
  • 1,805 posts
Posted 05 February 2010 - 03:31 PM
#5 Ethel
  • 25,949 posts
Posted 05 February 2010 - 03:48 PM
Silicone is the insulation material, inside they are just carbon impregnated string like the rest. Copper leads are best, but you will need some form of suppression on a road car which will cancel out any advantage.
#6 ste88
ste88
  • 258 posts
  • Local Club: LCMOC
Posted 05 February 2010 - 03:59 PM
i got some bosch ones off ebay, think they are silicon ones. They are resisted and i use the BP6ES plugs, i think you can get non resisted leads and resistor plugs too but im not sure. Anyway, mine seem to work OK :(
hope it helps
#7 scoticus
scoticus
  • 1,805 posts
Posted 05 February 2010 - 04:00 PM
Thanks guys...
Big help
Copper it is :(
#8 camp freddy
camp freddy
  • 3,696 posts
Posted 05 February 2010 - 11:03 PM
Thanks guys...
Big help
Copper it is :lol:
I bought some Luminition ones from Mini spares and you get TMF+ discount
if you are a member...
http://www.minispare.....ILICON FROM...
Edited by camp freddy, 05 February 2010 - 11:09 PM.
#9 taffy1967
taffy1967
    Whovian
  • 9,896 posts
Posted 06 February 2010 - 12:21 AM
Thanks guys...
Big help
Copper it is :lol:
http://www.minispare......ILICON FROM...
Yes I've got those (part no. HV22) on my Mini and their fantastic.
#10 Ethel
  • 25,949 posts
Posted 06 February 2010 - 12:39 AM
I've been a saddo 'n done a bit of reading up...
Carbon leads will give about an ohm of resistance, which should just be enough to stop you adding a drum 'n base beat to your neighbours telly. Resistor plugs, and most resistor plug caps are about 5 ohms, which is still way too low to have much effect on the quality of the spark (negligible compared to the resistance of the plug gap). Copper's real advantage is that it doesn't deteriorate like carbon. Spiral wound leads (like Taffy's) vary the resistance along the lead which further helps to suppress interference.
#11 taffy1967
taffy1967
    Whovian
  • 9,896 posts
Posted 06 February 2010 - 01:01 AM
Cheers Ethel, either way my Mini finds those leads and NGK BPR6ES spark plugs to be very agreeable.
:lol:
#12 sazal
sazal
  • 3,512 posts
  • Local Club: DCMOC
Posted 06 February 2010 - 12:16 PM
I think ive got the silicone ones on my mini and am pretty sure I always have had! My last couple of sets I've had are from unipart, but mainly because there were unipart ones on the car when I bought it and I never had any problems with them :thumbsup: Beware of cheap leads though, I've had a couple of sets that are nasty and don't clip onto the plugs properly.
