Radius Arm Grease Nipple
17 replies to this topic
#1 mister bridger
mister bridger
  • 911 posts
Posted 05 February 2010 - 02:36 PM
For the year or so I've been running this car it has had a broken off grease nipple on the drivers side radius arm. I'm chuffed that with a little effort I've managed to get the broken off part out and am now off to try and get a replacement. I seem to have got away with it as there's no apparent play in the radius arm, but when i put the new one how much grease should I put in? Just keep pumping away? oo er missus!
#2 danie garry
danie garry
    I love BMW minis
  • 2,296 posts
Posted 05 February 2010 - 03:19 PM
put it in til u can see it oozing out behind the rubber at the back of the arm
#3 WiredbyWilson
WiredbyWilson
    WiredByWilson
  • 5,004 posts
  • Local Club: WiredByWilson
Posted 05 February 2010 - 03:21 PM
Pump away till it oozes back out! oooooo matron!!
#4 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 05 February 2010 - 03:33 PM
nuff said
#5 mister bridger
mister bridger
  • 911 posts
Posted 05 February 2010 - 04:57 PM
Well that should have been a nice easy task but I've spent the entire afternoon trawling round every garage and motor factor I can think of and NO-ONE has ANY grease nipples. Grrrrr!
#6 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 05 February 2010 - 05:13 PM
Cars don't use grease nipples any more. Try an engineering supplier or a lawn mower centre. (or a Mini specialist obviously) Make sure they are imperial threaded.
#7 jonny d
jonny d
  • 1,148 posts
Posted 05 February 2010 - 06:20 PM
Hi there If the grease tube within the radius arm is fractured you can end up filling the whole radius arm up with grease, I have one on my car like this and i pump away for ever before i see grease come out of the bearing ends.
#8 minimender
minimender
  • 1,589 posts
  • Local Club: M.M.M.
Posted 05 February 2010 - 06:28 PM
these what your lookin for ?
http://www.frost.co....sult_search.asp
made a mess of the link but if you search on the site for grease nipple they have them in imperial sizes.
Edited by minimender, 05 February 2010 - 06:31 PM.
#9 Big_Adam
Big_Adam
  • 7,435 posts
Posted 05 February 2010 - 08:32 PM
Errm, can't do that sort of link on that site. Blame the ASP.net.
#10 Punts
Punts
  • 137 posts
Posted 05 February 2010 - 08:46 PM
Try an agricultural engineering workshop for the grease nipple, they usually have selection boxes of them
#11 njathind
njathind
  • 447 posts
  • Local Club: Chichester Mini Club
Posted 05 February 2010 - 09:39 PM
I have just brought a 1998 1.3mpi mini cooper
The guy has hardly driven it all year and so as a result has not seen th need to grease the rear radius arms, the only times he drove it were to and fro from work to keep the baterry charged and keep the engine ticking, I had to drive it 200 miles to get it home and there eas no play, it tracked straight and true, do you think the radius arms ore ok?
#12 minimender
minimender
  • 1,589 posts
Posted 05 February 2010 - 10:01 PM
Sorry, not spam just trying to help.
How does one point people in the direction of hard to find bits without mentioning names, or is it just not allowed.?
I've seen rolling roads recomended on here so what's the difference?
#13 timmins
timmins
  • 109 posts
  • Local Club: Mid Atlantic Minis
Posted 05 February 2010 - 10:23 PM
He's saying the type of link you used won't work when clicked, because of the type web application their site uses.
#14 nicksuth
nicksuth
  • 1,631 posts
Posted 05 February 2010 - 10:51 PM
Try Lumatic, they're on your doorstep - Clicky
#15 taffy1967
taffy1967
    Whovian
  • 9,896 posts
Posted 06 February 2010 - 01:22 AM
Which isn't a bad thing because an arm full of fresh grease is far better than an arm holding dirty water, as I found out when I greased the rear radius arms on a relatives 98 Mini Paul Smith LE a good few years ago. Because dirty water sprayed out before any grease made an appearance and we went through a few tubes I can tell you.
Once it's all greased up nicely, it won't need so much on future greasing.
Edited by taffy1967, 06 February 2010 - 01:22 AM.
