160bhp
Posted 07 February 2010 - 10:53 PM
It's for a fast road car that does alot of weekend and track time??
Preffered supercharging as I like the idea/noise lol
Posted 07 February 2010 - 10:58 PM
Posted 07 February 2010 - 11:02 PM
Posted 07 February 2010 - 11:05 PM
Posted 07 February 2010 - 11:11 PM
you not go for a k1100 head with a T2-3 on?
Posted 07 February 2010 - 11:26 PM
as an example mines a totally std bottom end bar the cam and pistons and its running a shade under 200hp. gearbox wise it's just a 4 syncro S/C box with SC drops and an ATB LSD. you'll probably want a pre-verto clutch setup with an AP rally plate and a grey diaphragm to cope with the torque that comes with 160hp from a forced induction motor.
Posted 07 February 2010 - 11:28 PM
Posted 07 February 2010 - 11:32 PM
I'm aiming for my car to weigh abotu 650kg so as much HP as possible would be good.
Realistically how far will £3500 get me?
Posted 07 February 2010 - 11:37 PM
Posted 07 February 2010 - 11:39 PM
So who and where in your experiece should I buy my parts and what do I buy?
Thanks for the help guys it is much appreciated
Posted 08 February 2010 - 12:07 AM
30 thousand miles is it bud its gone through in various states of tune? But same base components?
yup, started out with std T3 and 10psi at 120hp, then a bit more headwork and a T25 and 15psi @ 165hp, now better turbo 20psi and 197.7hp, lol.
all still on the same bottom end, think i might have fitted new shells at some point when my clutch pedal was sticking and burnt out my thrusts, but the pistons/bores are still the same and just starting to get a bit loose now.
£3500 might get you some of the way there, all depends how much you can do yourself.
you're going to be looking at spending £800 on box and drops, or more if you want an lsd.
bottom end would be somewhere in the region of £600ish, say £350ish for a head.
Then it's all the little bits and bobs that add up, flywheels, clutches, radiators, piping, carbs, turbo, manifolds etc etc etc...
whatever you think your budget is you need to add on at least 1k for all the bits you didn;t think of.
Posted 08 February 2010 - 11:49 AM
and the rest
Edit: this was meant to be in your build thread bud, how i got it in here i dont know? lol
Edited by Brett, 08 February 2010 - 12:05 PM.
Posted 08 February 2010 - 06:28 PM
my old car was matt black and T3'd, the engine got transfered over to this one at the same time the T25 went on.
Posted 08 February 2010 - 07:00 PM
Cheers Ross.
