Windscreen Wipers
6 replies to this topic
#1 chappy
chappy
  • 1,253 posts
Posted 09 February 2010 - 10:11 AM
Model: city
Year: 1992
Hi Guys,
Just wondering, if theres anyway to make the wiper motor any faster? just the standard 'fast' setting is.. well... its not. :thumbsup:
would just clearing out all the old grease and putting in new stuff make a difference? or is it something i'll have to deal with?
Sam
#2 josh.evans
josh.evans
  • 1,439 posts
Posted 09 February 2010 - 10:16 AM
i would like to know about tbis aswell cause mine are slow!
josh
#3 finch661
finch661
  • 2,339 posts
Posted 09 February 2010 - 10:24 AM
give the wheel boxes a good service, strip is all down, remove the old grease and use something like vasaline to lube the boxes and drive. also clean up all the electrical connections. i almost replaced my motor, but i found out that my fuse box terminals were naff, and that casued little power being sent to the motor
oh and the mini wipers arent amazingly quick, but they do the job (kinda like the car...)
Edited by finch661, 09 February 2010 - 10:25 AM.
#4 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 09 February 2010 - 10:42 AM
Yes, old grease will make a big difference. As will old wiper blades and worn motor brushes. Do you have a fishing scale? With the blades off the screen and the motor disconnected from the rack try to pull the rack gently out of the housing with the scale. It's meant to be under 7lbs of pull, that's what the motor can cope with.
You are supposed to use something called Ragosine Listate Grease, but nobody in the entire world knows what that is. (seriously, if you Google it you will mainly get responses from this very forum and from Land Rover forums with people asking what on Earth it is). Ragosine oil don't exist any more AFAIK. You can use LM grease, I wouldn't use Vaseline. Use a little light oil on the gear shaft bushes too (not the motor shaft).
Other things that make a difference are the pre-load on the motor spindle and the cone washer under the drive gear. The pre-load can be adjusted, it will change over time so bringing it back to what it should be is a good thing. When you have it apart, inspect the cone washer. Often they are rusted and crumbling at one edge. This cone is a spring that supports the gear, if it's in bad condition it adds drag to the gear and also allows the gear to slop around. New ones are available, make sure it's fitted with the narrow end down towards the housing and is lightly greased. Once you've got the gearbox clean and regreased but the motor still out of the car, slacken off the screw on the end of the gearbox casing that faces the motor spindle. Hold the motor upright with the gearbox at the top and turn the screw in until you can just feel resistance, then slacken it off 1/4 of a turn. That sets the pre-load to what it should be, if there is too large a gap here then a lot of the motor action becomes lost motion with the motor shaft jumping in and out of the motor as the gear turns and the load on it changes.
They don't have to be slow, the same motor and system was used on many cars but people think that because it's a Mini it's different. When they were new they worked just fine, the problem is most Minis are poorly maintained.
#5 chappy
chappy
  • 1,253 posts
Posted 09 February 2010 - 11:15 AM
can you replace the motor brushes? or is it just worth getting a new one?
#6 icklemini
icklemini
  • 2,982 posts
Posted 09 February 2010 - 11:19 AM
Sam - got one in the workshop that should do the job :thumbsup:
#7 Ethel
  • 26,022 posts
Posted 09 February 2010 - 11:22 AM
http://minispares.co...a...R BRUSH KIT
that's almost half the cost of a whole motor.
Back in the day, you just went to the scrappers as every other car used the same motor.
