Door Window Wonky :s
14 replies to this topic
#1 minicityjimmy
minicityjimmy
  • 12 posts
Posted 09 February 2010 - 05:08 PM
just wondering if anybody could help me out. My drivers door window on my city has some how slipped so it now goes up and down at an angle! How do i get the widow out so i can re-aline the runners? many thanx
#2 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 09 February 2010 - 05:11 PM
you have either slipped a cog or the bit that holds the glass has rusted away
you need to remove the door card and with draw the winder mechanism for a look
it's all the the haynes with pictures :o
#3 xBR4DLEY
xBR4DLEY
    >>mine's still gay<<
  • 1,618 posts
Posted 09 February 2010 - 05:30 PM
Mine has done it but luckily the door is off , its could be what has already been mentioned or the glass is not sitting on the rubber or on the winder mechanism properly.
#4 minicityjimmy
minicityjimmy
  • 12 posts
Posted 09 February 2010 - 06:12 PM
looking at it with a torch im pretty sure its slipped a cog, but its bit dark and cold to start fiddling now wait til tomorrow to sort :o
#5 taffy1967
taffy1967
    Whovian
  • 9,896 posts
Posted 11 February 2010 - 12:10 AM
I bet the glass regulator channels (or whatever their called) have rusted away and collapsed.
#6 [email protected]
[email protected]
    Minispares
  • Minispares
  • 3,229 posts
  • Name: Simon Jackson
Posted 11 February 2010 - 09:09 AM
Thats what usually happens, not usually the cogs etc
#7 ROD
ROD
  • 2,215 posts
  • Local Club: MCR
Posted 11 February 2010 - 09:22 AM
^^^^^^That's what was wrong with mine. :)
#8 alicetheauto
alicetheauto
  • 1,222 posts
  • Local Club: Rusty Nuts Minis, Leicester
Posted 11 February 2010 - 09:58 AM
And mine... I found that if I tapped the bottom of the door it sounded like there was rust scale moving inside. Because the rusty bits fall to the bottom! Are the doorskins themsleves ok? Or bubbly? If they have some rust on too then its more likely the car has some rust inside :)
#9 biggles1293
biggles1293
  • 167 posts
Posted 11 February 2010 - 10:14 AM
Same problem with mine on the drivers door, was a right pain in the backside, the runner channels holding the glass had rusted away, after a bit of fettling and filing and squeezing the runners onto the glass with some pliers it seems to be holding! Not the best design, but quite a common fault
#10 CGilmour
CGilmour
  • 68 posts
Posted 11 February 2010 - 11:19 AM
I had this problem few weeks back,
In the end it was caused by a bent tooth on the cogs and the rail slighty bent, i took it all appart got all the rust off, greased it all up, bent it all back, painted the outside of the runners to prevent futher rusting and now its working really smooth :)
Its all in the haynes, its not a hard job... my advice would be to get somone to hold the window tho while you are taking it appart :)
#11 shorty
shorty
    Short Guy
  • 3,606 posts
Posted 11 February 2010 - 11:31 AM
yep mine are rusted away that much the glass popped out of them on a nice cold mrning :)
there not to expensive of minispares if that is the problem
#12 simon w
simon w
  • 14 posts
Posted 11 February 2010 - 12:05 PM
the arms on the window mechanism bent on myn and became wrong length.
so the window wunt go up and down straight in the window runners
had to replace window mechanism. may be same. good luck dude
#13 taffy1967
taffy1967
    Whovian
  • 9,896 posts
Posted 11 February 2010 - 10:39 PM
If it is the regulator channels or rails which have rusted away, then you just need these: -
Click Me.
#14 Darkscamp
Darkscamp
    Drives the 'Thing'
  • 1,475 posts
  • Local Club: Lone Ranger
Posted 11 February 2010 - 10:46 PM
this kind of thing always happens at night :P
thats why i went for the no glass, no door system. it gets rid of little problems like this :thumbsup:
on a serious note: if you cant get someone to hold the window for you, get a couple of bits of wood, put the window right up(with your hand if needs be). push the wood through the holes in the door and this should hold it safely while you work on the mechanism.
#15 taffy1967
taffy1967
    Whovian
  • 9,896 posts
Posted 11 February 2010 - 10:51 PM
Also grease up the new regulator channel/rails so they don't rust out again any time soon. Grease the winder mechanism too and whilst you're at it, you could spray some Waxoyl into the door bottom. That should keep it rust free and you'll be killing two birds with one stone at the same time.
