Cv Joint
6 replies to this topic
#1 djdobson
djdobson
  • 150 posts
Posted 10 February 2010 - 12:07 PM
1990 mayfair
need to know if it is the cv. as im driving along i can hear a squeeking and then a scraping and then sometimes a knock from what sounds like the passenger side of the car.
anyone kno what this could be?
i have had the wheel off and regreased all the joints and there didnt seem to be any play in the bearings..
someone please help as im stumped
#2 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 10 February 2010 - 12:12 PM
Sounds like something stuck in the brake disc. Generally failed CV joints click loudly when you drive around tight corners.
#3 djdobson
djdobson
  • 150 posts
Posted 10 February 2010 - 12:14 PM
i have had the brake off and checked it and there is nothin there that why i really struggling with this.
it only started doing this the other week because my hub nut came loose and when i torqued it up it started off as a squeeke and just gets worse :thumbsup:
#4 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 10 February 2010 - 01:29 PM
Your wheel bearing is dead, the CV joint shaft may also be worn and unusable or the hub itself may be worn. The noise may be the bearing race slipping. The nuts don't just come loose, something must have allowed it to slacken off and you need to strip this hub to find out what. Was the split pin still in place? Taper roller bearings cannot be taken up when they start to wear in that way, once worn they are worn and must be replaced.
#5 beentheunseen
beentheunseen
  • 200 posts
  • Local Club: Notts about Minis
Posted 10 February 2010 - 08:24 PM
I did once have a hub nut that came loose on it's own, i think a previous mechanic had forced a metric nut over an imperial thread (or vice-versa) and completely destroyed it to the point where it would slowly and surely undo itself... As it started to come undone the taper washer would vibrate under braking creating strange creaking/scraping noises like you are describing... Could be worth looking closely at your drive shaft thread/hub-nut to make sure a similar bodge hasn't been done on yours... Also, if it's been running loose the drive flange might be excessively worn on it's inner face - I ended up replacing the flange, cv joint (just because the thread was such a mess), bearings, and hub-nut although mine was kind of an extreme case.
Edited by beentheunseen, 10 February 2010 - 08:25 PM.
#6 bmcecosse
bmcecosse
  • 9,699 posts
Posted 10 February 2010 - 08:28 PM
As above - nut coming loose indicates serious problems. Beware -the bearing CAN suddenly seize solid and slew the car - nasty if in the fast lane! I would advise to NOT drive the car until you get this fixed. May now need new CV joint, new taper washer, new nut, possibly new hub carrier - and of course the new bearings it would have needed if you had acted right away.
#7 djdobson
djdobson
  • 150 posts
Posted 11 February 2010 - 09:06 AM
excellent cheers for all the help. i will get this sorted. :)
