What Difference Does This Make To My Engine?
4 replies to this topic
#1 samperks
samperks
  • 467 posts
  • Local Club: looking
Posted 10 February 2010 - 10:08 PM
Make:Rover Mini Tahiti
Engine:1275
Eng num:12A2BG03278638
L Registration
Source Vehicle : Mini
Engine type & CC : A+ 1275 cc Transverse mounted
Fueling : HIF38 MAC10031, AEM Needle, Red Spring
Engine features : 9.4:1 Compression Ratio
Servo Assisted Brakes
95 Ron Unleaded petrol
Open Loop Catalyst
Pre-engaged starter
Gearbox features : Std. Ratio Rod Change gearbox with Pot Joints
3.105:1 Final Drive
What does this mean>>>> HIF38 MAC10031, AEM Needle, Red Spring
and how can i upgrade the carb?
#2 lrostoke
lrostoke
  • 6,923 posts
Posted 10 February 2010 - 10:15 PM
HIF38 is the carb type its a 38mm SU carb
AEM is the needle spec, needles come in different taper profiles to given different fueling for different spec engines. each profile as a different letter code.
The spring is in the top dome bit of the carb, the red is the strength of the spring.
Main upgrade for a 1275 would be the HIF44, its a bigger carb.
#3 bmcecosse
bmcecosse
  • 9,699 posts
Posted 10 February 2010 - 10:20 PM
But - that engine probably has the very soft camshaft - and so power may not be limited by the smaller HIF38 carb. In other words - fitting a larger 44 carb on it's own may not noticeably change the performance.
#4 samperks
samperks
  • 467 posts
Posted 10 February 2010 - 10:36 PM
what type of new carb should i buy then?
whats the best type or brand i van buy? any suggestions?
#5 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 10 February 2010 - 10:52 PM
Why do you want to? Carbs don't make power, it's the engine that does that. All the carb does is mix fuel and air and if it's already doing that as efficiently as the engine is capable of using it and providing as much as the engine needs then changing the carb will do nothing. If you want your engine to produce more power or more torque or be more responsive then you really need to be working on the engine. If it needs a change of carb as a result of what you do to it, that's when you would think about changing it.
