998 Stage 3 Head? Any Good?
Posted 11 February 2010 - 12:52 AM
what sort of power increase will i get also will it be noticeable?
are they easy to fit
and are they worth the money
hope you can help
cheers
josh
Posted 11 February 2010 - 12:06 PM
See the links to stages of tuning for A Series at the top left of the home page.
For an immediate increase in performance changing to a 1275 would probably be cheaper.
Edited by IainR, 11 February 2010 - 12:07 PM.
Posted 11 February 2010 - 12:18 PM
My understanding is that a stage 3 head would need a lot of other changes, i.e. manifold, carb, exhuast and cam to make a difference. A stage 3 head on its own would be useless, it would need the camshaft changed.
Would it definately need a cam change? i have been running a stage 3 head on my mini, with exhaust system, mg carb and 1.5 rockers and a standard cam with no problems.
having a look at the likes of a minisport stage 3 kit for a 998, they provide everything you suggest in their kit, apart from the cam. just saves the whole engine out jobby?
ps. i am still learning myself, not arguing, so just tryin to understand.
Edited by PhilRobbo, 11 February 2010 - 12:20 PM.
Posted 11 February 2010 - 12:24 PM
Posted 11 February 2010 - 12:37 PM
I run a 998cc stage III, I know lots of folk say always go straight to 1275, but I can (sometimes) run in a 1000cc class and then I'm extreemly compeditive.
I have the 276 cam LCB, with gas flowed inlet but only HS2's.
I'm getting about 70BHP and it's quite quick enough to give the 1275's a run for their money.
Cater_racer
Posted 11 February 2010 - 12:56 PM
70Hp....Really?Hi Josh,
Cater_racer
i think you might of been on some fairly optimistic rollers!
Posted 11 February 2010 - 01:35 PM
Posted 11 February 2010 - 01:43 PM
I didnt feel a great power increase with the cam and im guessing the standard head was the limiting factor.
Id rather get a stage 3 head as i love showing up chavs in there corsa's and fiesta's with a 1 litre . With this sort of setup what sort of Hp boost would the aformentioned stage 3 head make?
Also Josh i belive that fitting 1.5 rockers would be the best route of gaining power if you do not wish to change the cam
Posted 11 February 2010 - 02:30 PM
Posted 11 February 2010 - 05:33 PM
The rolling road reckons it makes 55 horse power, which is exactly what the guy tuning said he expected it to achieve.
Posted 11 February 2010 - 09:15 PM
on another note i fitted 1 of these heads on my 998 with a 997 cooper cam, hif 38, stage 1 kit, all this gave 44bhp @ the wheels so about 55-60 at the flywheel even tho at the time i had ruined piston rings so the compression was down from 180psi to only 130psi
whatever you decide to do good luck
Posted 11 February 2010 - 09:23 PM
But note he is (v wisely) changing it to fit a 940 head!
Edited by bmcecosse, 11 February 2010 - 09:24 PM.
Posted 12 February 2010 - 02:33 PM
So that's engine out anyway......................................
And I needed cold plugs, without extended extrodes to avoid running on, but both of these maybe due to the head, and as has been said, there's no real standard Stage III.
Minisport rolling road, did the final set-up, I was very pleased with their standard of customer service and skills.
Posted 13 February 2010 - 01:48 PM
get yourself a 12g295 head off ebay or somot get it skimed cost will be half the amout that an off the shelf stage 3 hed will cost from any of the major supplyers.
my mini has a stage 1 kit on it got a dyno print out with 47 bhp at the wheels!!
56 at the flywheel
Posted 13 February 2010 - 07:38 PM
