Dished Steering Wheel
17 replies to this topic
#16 Sleepy Stu
Sleepy Stu
    formerly Stewart_GT
  • 2,564 posts
Posted 12 February 2010 - 08:16 PM
This boss has a doubled set of holes for two different layouts so should definately fit.
https://www.plminish...uct-B-RAID.html
It fits fine with my Sparco wheel and the snap boss that I fitted.
#17 Dan16v
Dan16v
  • 370 posts
Posted 14 February 2010 - 03:33 PM
As long as the PCD on the mounting holes of the boss are 70mm then that wheel will fit, :thumbsup:
ok, so if my current mountney boss has a PCD of 70mm, the wheel should fit? sounds like a good option if it gives some more leg room, I need to chop a section out the rear bin to get the seat back further which is a bit of a pain
Yea should do ;)
My Mountney boss has a 100mm PCD, so I expet I will need a new boss :(
#18 the-green-monkey
the-green-monkey
  • 255 posts
Posted 14 February 2010 - 06:38 PM
Id contact the company you are thinkng of buying the wheel from just to make sure that it does have a 70mm PCD but seems like you will unfortunately need a new boss :thumbsup:
