Purge Valve wiring connector
17 replies to this topic
#1 AlexM
AlexM
  • 1,302 posts
  • Local Club: NMOC, ECMC
Posted 28 October 2005 - 09:24 PM
On the passenger side of my engine bay there is a connection to what i believe is the purge control valve, the only thing is that the wires that are supposed to fit into it just hang loose (one is black and the other white).
So, does anyone know the name of the wiring connector plug thing that i am lacking that should plug into the cylindrical holes on the valve and be connected to the black and white wires? :lol:
#2 AlexM
AlexM
  • 1,302 posts
Posted 29 October 2005 - 06:52 PM
No one? :sad:
#3 Sprocket
Sprocket
    Great on Injection faults
  • 7,266 posts
Posted 29 October 2005 - 09:22 PM
Don't quite understand what you are getting at :lol: :w00t:
The purge valve is just a solenoid so requires a ground (Black) and a posative (white fed from the ecu)
#4 funkygibbon
funkygibbon
  • 174 posts
Posted 31 October 2005 - 12:59 PM
I know what you mean mate, i'll try and find out later when i get home!! how long has it been like that? Who would just cut the connector off?? Wierd.....
#5 chairchild
chairchild
  • 606 posts
Posted 31 October 2005 - 11:29 PM
AFIK, if it plugs into the small cylindrical connector, under the purge valve, and besides the fan connector - thats for the dim/dip ballast resistor
If you really wanted to, you could just use bullet connectors
#6 Slimer
Slimer
  • 60 posts
Posted 01 November 2005 - 04:20 PM
now that you mention it, mine is not connected either :gimme:
what exactly is the reason for the purge control valve :cry:
#7 chairchild
chairchild
  • 606 posts
Posted 01 November 2005 - 06:16 PM
it lets the engine suck air through the charcoal cannister, which stores the fumes from the fuel tank whilst the engine's off
it only opens "under certain conditions" according to Haynes, so I'm guessing at anything above idle!
I suppose there wouldn't be any harm to simply have it on with ignition, although it may increase the idle speed slightly
#8 funkygibbon
funkygibbon
  • 174 posts
Posted 01 November 2005 - 08:30 PM
Like this!!
#9 funkygibbon
funkygibbon
  • 174 posts
Posted 01 November 2005 - 08:31 PM
and this!!!
#10 chairchild
chairchild
  • 606 posts
Posted 01 November 2005 - 10:17 PM
I once left mine disconnected for about 20 miles before I remembered to reconnect it (along with the wipers!)
didnt have any obvious side-effects?
#11 Sprocket
Sprocket
  • 7,266 posts
Posted 01 November 2005 - 11:32 PM
I recon you can get the exact plug from demon tweeks. I got some for the spot lamps and look almost identical. I'll check it out tomorrow.
The plug comes in a kit with both male and female parts and also the terminal pins and seals.
http://www.demon-twe...RT&pcode=LMA860
#12 Slimer
Slimer
  • 60 posts
Posted 02 November 2005 - 09:31 AM
I don't see an charcoal canister anywhere in my engine bay either. This could be why I have a strong fuel odor after the car sits a while?
#13 funkygibbon
funkygibbon
  • 174 posts
Posted 02 November 2005 - 12:57 PM
Slimer, the canister is actually under the offside wing!!! you'll only see it if you look up under the wheel arch..
The purge valve is in the engine bay which is what you can see in the photo. it should have a tube or maybe 2 tubes which go through the inner wing into the wheel arch.....
#14 funkygibbon
funkygibbon
  • 174 posts
Posted 02 November 2005 - 01:02 PM
Just check out Demon Tweeks and found this connector..... i would say that Mini Sprocket is right looks like the one...
This could be the one!!!!
#15 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 02 November 2005 - 02:13 PM
'Certain conditions' pretty much means only when the engine is in high speed over-run and at proper operating temperature. It will open at some other times but that's basically it.
...and only on injection cars. If you don't have injection you shouldn't have one so don't worry about it.
