Tyre Pressures
Posted 12 February 2010 - 03:12 PM
Posted 12 February 2010 - 03:25 PM
Posted 12 February 2010 - 03:43 PM
165/60r12, Yoko A539'sThe tyre size is a lot more relevant than the rim size!
Sorry, just thought the tyre size would be the same for rims of that size and I was just being lazy not going out to the car in the cold!
Posted 12 February 2010 - 03:56 PM
Posted 12 February 2010 - 04:34 PM
does it make any difference to handeling
ive got 10x6
165/70/10 i think
sorry for post robbing
Posted 12 February 2010 - 04:46 PM
guess works, whats the reason behind this??? as i just shove 32 in all round!
ive got 10x6
165/70/10 i think
I just put 30psi all around, works fine for me
Posted 12 February 2010 - 05:09 PM
ive got 10x6
165/70/10 i think
Wow that's way too high. 165/70 R 10 tyres on a Mini should be at 24 front 26 rear really but you can work from that to find a pressure you are happy with. Yes it affects handling, it affects everything. Your car must feel like it has power steering! Are you not wearing the tyres in their centres?
Posted 12 February 2010 - 05:10 PM
The front of your car is heavier than the back, therefore you need more air ( higher pressure ) in the front than the rear for the same contact patch for the tyre. The higher the pressure the smaller the contact patch...
This is why over inflated tyres wear on the middle of the tyre, and under inflated tyres on the outside.
What you want to obtain by pumping up your tyres is the optimum pressure to provide the optimum tyre contact patch on the road.
You could go into the complexities of corner weight, tyre design and pressures, but it's not really worth the effort.
Posted 12 February 2010 - 05:12 PM
but the tyres have lasted for ages sofa! and the stearing isnt much lighter then when i had my 13"s
Posted 12 February 2010 - 05:14 PM
Posted 12 February 2010 - 05:16 PM
has a metro lump in it but that cnt be any heavier then anyother a series???
Posted 12 February 2010 - 05:50 PM
Posted 12 February 2010 - 05:56 PM
