How Much Power/torque Can A Helical G/box Handle?
Posted 12 February 2010 - 09:10 PM
At what point do you think you need to switch to straight cut gears and which is the way to go, SC drop gears or SC everything?
I have tried different searches but can't find what I'm looking for, maybe I missed it?
Posted 12 February 2010 - 09:15 PM
some people get away with more, some break stuff with less, mechanical sympathy has a big influence.
Posted 12 February 2010 - 09:19 PM
Posted 12 February 2010 - 09:23 PM
however.
if you try to put 200hp through a std helical box the teeth will fall off rather rapidly, if you use a good straight cut box it will last.
Posted 12 February 2010 - 09:46 PM
As said mechanical sympathy goes a long way. I would say that the standard ratios are badly spaced and this is exagerated as you get more power, as the power tends to get more peaky. So once over 130bhp it's worth it anyway.
I'm currently planning a 120bhp build using standard dropsand box with a cross pin diff.
Posted 13 February 2010 - 07:06 PM
Posted 13 February 2010 - 07:15 PM
The main reason that straight cut gears are prevalent in competition gear kits is simple, they are much much cheaper to design and make.
Posted 13 February 2010 - 07:24 PM
Doesn't Robrt run 180bhp with a helical box?
agreed, however if you can source a s/gt close ratio box and match it with a good final drive then your ok
Posted 13 February 2010 - 08:16 PM
I know robert destroyed a helical box at 150ish hp, it was rebuilt as a straight cut in the thread below, i thougght ihe was still S/C.
http://www.turbomini...p...68594&fr=50
Posted 13 February 2010 - 09:09 PM
Posted 14 February 2010 - 07:42 AM
Once you're into the mid 100's in torque or power then you should be upgrading your gearbox with a X-pin and SC drop gears... The SC drops prevent the idler gear from disappearing out of the transfer case, the need to change from the std helical gears is more a personal preference than a requirement...
GT gears are an alternative, however, unless you are really lucky and have one of the last sets made which actually run the A+ mainshaft and laygear, then you are hampered slightly by having to use A series main shaft and laygear which are weaker in their use, smaller bearings.
Posted 14 February 2010 - 12:48 PM
Unless you can find some early GT helial gear sets, you are stuck, in helical form gearing, with wide ratio gears, even though they may unsuitable for 'hot' and cammy engines, which is why SC gears are now widely used. Thus SC gears are now used to keep hot engines 'on-the-cam', even though the materials from which they are made may not be as good as the original 'works' SC gears.
Posted 14 February 2010 - 12:56 PM
Robert has an SC box but still has helical drops.
Posted 14 February 2010 - 04:37 PM
Wil
That makes sense, I knew he still used some helical bits.
