How Can I Minimize Torque Steer?
Posted 13 February 2010 - 10:00 PM
I was just reading on minispares about their crosspin diff, and they say that it reduces torque steer, so if thats tre,
can fit one without having to pull the engine out? Id go lsd but theres no way i can afford one at the mo..
Also its a 1293 with a 256 cam, 1.5 rockers, stage 4 head, its got fixed -1.5° bottom arms, heavy duty adjustable tiebars, all polybushed, spax shockabsorbers.
A thought that popped into my head was that it could be something to do with he tracking or caster, but it drives straight at a constant speed and feels good in corners.
So any ideas how i can minimize it, its a bit scary in the wet..... Thanks
Posted 13 February 2010 - 10:07 PM
Posted 13 February 2010 - 10:09 PM
Edited by samsernie, 13 February 2010 - 10:11 PM.
Mine torque steers a bit, the more toe out on mine, seems to cause make it worse.
Posted 13 February 2010 - 10:12 PM
Posted 13 February 2010 - 10:58 PM
Posted 14 February 2010 - 08:03 AM
If you wamt to reduce torque steer to a minimum and you do have the power..... then fit heavy duty rose jointed bottom arms and tiebars
Posted 14 February 2010 - 08:12 AM
What wheels are you running?
Posted 14 February 2010 - 09:42 AM
Just worth pointing out that the cross pin diff will make zero differance to a normal open diff, no matter what Mini sport say.
Second that!
Posted 14 February 2010 - 12:27 PM
Posted 14 February 2010 - 12:38 PM
It should not torque-steer much with your engine spec. However, if you have too much neg camber that wouldn't help and if your tyre pressures are a bit high with lots of neg camber that would make it worse.
Is the sub-frame solidly mounted?
Posted 14 February 2010 - 12:54 PM
Posted 14 February 2010 - 05:55 PM
Now that the fronts all set up, it has a lot less torque steer, its still pulls to the right a tiny bit when you plant it, but it feels a lot safer now, lol
Posted 14 February 2010 - 06:06 PM
chances are you can get a rough idea from that.
Posted 14 February 2010 - 06:08 PM
Edited by samsernie, 14 February 2010 - 06:08 PM.
