Maestro Turbo
8 replies to this topic
#1 nath
nath
  • 247 posts
Posted 13 February 2010 - 10:03 PM
hi does anyone no if a meastro turbo will fit straight into a mini or what would need to be done
thnks :)
#2 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 13 February 2010 - 10:19 PM
just the turbo or the whole engine ?
#3 nath
nath
  • 247 posts
Posted 13 February 2010 - 10:32 PM
whole engine??
or whats the turbo worth??
#4 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 13 February 2010 - 10:40 PM
a meastro engine is more like a inline MG engine than a mini engine
the gear box sits on the end of the engine making it too wide
the engine can be converted to run a minis in the sump gear box but it's a lot of work, i think Guessworks has done the conversion
#5 mini13
mini13
  • 3,810 posts
Posted 14 February 2010 - 12:02 AM
mastro turbo engine is an E or O series,
not a chance of getting it into a mini unless you build a chole new subframe to take it.
#6 me madjoe 90
me madjoe 90
  • 1,238 posts
  • Local Club: Fylde Mini Club
Posted 14 February 2010 - 12:05 AM
may be able to use turbo tho?
#7 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 14 February 2010 - 07:34 AM
Depends what it is, but at the maestro turbo is a 2 litre engine, unlikely...
#8 Wil_h
Wil_h
  • 3,244 posts
Posted 14 February 2010 - 08:09 AM
The only parts that can sensibly be used are the carb, plenum, FPR and maybe fuel pump depending on fitment. The turbo has a 10psi actuator which goes straight on the Metro T3, but the turbo its self would be no use on a 1300cc.
#9 Cables
Cables
  • 20 posts
Posted 14 February 2010 - 10:01 AM
have you the whole car, not against transplants, but surely nowadays a maestro turbo is a very rare beast?
