Advice On Engine/subframe Swap And Flip Front
Posted 14 February 2010 - 12:59 PM
my question is, what would be the easiest way of going about this? my first thought was to start by cutting away the front end, as if i was just doing a flip front conversion. then, disconnect the auto engine and subframe as a whole piece and wheel it away, then wheel the whole assembly of 1275 engine and subframe into place. then get on with the fitting of the flip front. does this sound reasonable? any suggestions for an easier way?
Posted 14 February 2010 - 01:29 PM
Personally I don't like flip fronts as I firmly believe that the majority give no structural integrity in the event of a 3/4 frontal impact. I used to work as a design engine in the aerospace industry and that colours my view of what constitutes good design practice in strutural engineering. I don't think the necessary stress calculations are carried out by those offering the flip fronts. They seem to think that welding/bolting a few bits of steel tube or steel angle in will carry the crash loads and that no calulations or rash tests are necessary.
But, hey, it's up to you in the end.
Posted 14 February 2010 - 01:34 PM
So long as the two sub-frames are of the same type mounting-wise, then do the sub-frame swap. It would be wise to use solid sub-frame mountings.
i plan on using solid subframe mounts. and when you say to do the sub-frame swap, do you mean subframe, then engine? or subframe engine combo?
Posted 14 February 2010 - 04:00 PM
It's good to have connected all the sub-frame parts onto the frame then ensured that, whilst it's still easy to lift, it all fits in nicely. Then it's so easy to lower the 'lump' in afterwards and just connect everything up.
