Removing Valve Guides
14 replies to this topic
#1 WiredbyWilson
WiredbyWilson
    WiredByWilson
  • 5,004 posts
  • Local Club: WiredByWilson
Posted 15 February 2010 - 11:32 AM
After a good chat with smart01 re head porting I have decided to tidy up the ports on my head myself before sending it th ethe machineists for guides and skimming.
So can anyone tell me the easiest way to get the old guides out with damaging the head? I don't have a vice or press by the way.
cheers
#2 PhilipGCaldwell
PhilipGCaldwell
  • 870 posts
Posted 15 February 2010 - 12:18 PM
i have heard of people putting them in the oven to heat it up then pressing them out. I wouldt fancy hammering them out incase it breaks the casting
#3 WiredbyWilson
WiredbyWilson
    WiredByWilson
  • 5,004 posts
Posted 15 February 2010 - 12:21 PM
Thats what i was worried about - will make it very difficult porting with them in :)
And im sure the mrs would object to putting it in the oven!
#4 01smartc
01smartc
  • 1,412 posts
Posted 15 February 2010 - 01:15 PM
Porting is easier if left in, the tool you are using tends to get stuck in the hole left from the guides.
Just knock them out so they are level with the casting on the inlets, the exhaust are normally level anyway.
We use a special punch, put it in the guide and gently knock it out.
Chris
#5 WiredbyWilson
WiredbyWilson
    WiredByWilson
  • 5,004 posts
Posted 15 February 2010 - 01:27 PM
Chris
So you mean grind and expose the exhaust port to the same degree that the inlet is as standard?
So you then with a suitable punch and patience i could tap them out enough?
#6 01smartc
01smartc
  • 1,412 posts
Posted 15 February 2010 - 02:02 PM
No i mean the guides are level with the guide boss in the exhaust port ... so kncok the inlets down level with the guide boss then start your grinding
Chris
#7 WiredbyWilson
WiredbyWilson
    WiredByWilson
  • 5,004 posts
Posted 15 February 2010 - 02:14 PM
Chris
Sorry i didn't explain very well.
The exhaust boss is much bigger in the exhaust port than the inlet port so would i be better porting then tappin gthe exhaust guide out to clean up the bit behind the guide (after removing most of the boss?)
#8 Turbo Phil
Turbo Phil
  • 2,426 posts
Posted 15 February 2010 - 05:25 PM
There's no need to heat the head or anything like that, & you'll not break the casting knocking them out, It's easy enough to make up a suitable puch with a shoulder on for knocking the guides out & far far easier to port the head with them fully removed.
#9 eden7842
eden7842
  • 907 posts
Posted 15 February 2010 - 06:06 PM
is refitting them as simple as removing them?
#10 Turbo Phil
Turbo Phil
  • 2,426 posts
Posted 15 February 2010 - 06:15 PM
Yes, basically. Make sure to set them to the correct height when istalling. {14mm}
#11 kez_19
kez_19
  • 946 posts
Posted 15 February 2010 - 06:48 PM
i made a tool for doing mine look here this worked perfectly and i didnt need more than a vice to press them out i wouldn't recommend banging them out as i think this can lead to cracks i believe its better to press them out slowly not shock them out
michael
#12 01smartc
01smartc
  • 1,412 posts
Posted 15 February 2010 - 06:55 PM
Turbo Phil - Really? You find it easier with guides removed? Doest you stone/carbide get stuck in the large hole? Just out of interest lol
Chris
Edited by 01smartc, 15 February 2010 - 06:56 PM.
#13 Pigeonto
Pigeonto
  • 973 posts
  • Local Club: ISMOC
Posted 15 February 2010 - 08:26 PM
Chris
This is what I have been doing ove the last couple of weeks too. I made a tool with a pilot to go into the guide which is a nice tight fit to support the walls of the guide just in case they tried to collapse.They arent all that tight really,but I have a large fly press so they may be actually.One important point I did learn is this;-If you dont need to renew them then only move them far enough down to do the porting then push them back because new ones WILL NOT BE CONCENTRIC WITH THE OLD ONES and the valve will be offset as a result, needing the seat re-cutting which is just a pain, worse if it is offset towards the other valve as they are too close together already
#14 Turbo Phil
Turbo Phil
  • 2,426 posts
Posted 15 February 2010 - 08:38 PM
I could have worded it slightly better. What I meant was fully removed from the port, rather than trying to port it with the guide protruding into it.
As already said, if installing new guides the seats will need to be recut.
#15 WiredbyWilson
WiredbyWilson
    WiredByWilson
  • 5,004 posts
Posted 15 February 2010 - 10:31 PM
The head will be going off to have unleaded exhaust seats fitted anyway so the seats will need to be recut - and if i knock the guides out I will just get the machine shop to refit them for me (think i was quoted for that within the £25 per seat cost for unleaded seats) plus the I know the guy quite well so hopefully can have a deal :D
