Ball Joint Shims
13 replies to this topic
#1 MiniBonkerz
MiniBonkerz
  • 1,893 posts
Posted 16 February 2010 - 09:54 PM
Got the hubs off the car at the moment and im doing the balljoints i have shimed all seem good but i was wondering how tight the domed nut needs to be so i can flip the edges up on the locking washer any ideas? i have a 38mm spanner big old thing and i have cranked it over by hand is this enough?
#2 Kam
Kam
    Straight to the Point
  • 4,140 posts
  • Local Club: 16vMini club
Posted 16 February 2010 - 10:12 PM
Needs to be ideally 75lbf ft or 102 Nm done up
I know your just shimming up but are you using genuine ball joints on there, too many problems with non genuine ones :D
#3 MiniBonkerz
MiniBonkerz
  • 1,893 posts
Posted 16 February 2010 - 10:14 PM
i bought them ages ago think the come from northwest minis would it be a good idea to buy another set then if so wheres the genuine ones?
#4 Kam
Kam
  • 4,140 posts
Posted 16 February 2010 - 10:37 PM
If you've had no problems with yours then there no reason to change and keep on re-shimming, If you want a new set then I recommend you get ball joints from minispares CLICKY. you can also try MRA CLICKY grease nipples are included on the MRA ones
Hth
#5 MiniBonkerz
MiniBonkerz
  • 1,893 posts
Posted 16 February 2010 - 10:43 PM
cheers kam :D
#6 Kam
Kam
  • 4,140 posts
Click below if you want the short answer :D
Straight to the point
#7 MiniBonkerz
MiniBonkerz
  • 1,893 posts
Posted 16 February 2010 - 10:45 PM
as i have no socket to use the torque wrench on it do you think a foot long hefty 38mm spanner cranked over by a beefy guy would sufice:)
#8 Kam
Kam
  • 4,140 posts
Posted 16 February 2010 - 11:01 PM
Problem with ball joints is you need to shim them and go through the trial and error method with the right shims before you torque them up for good and flatten the tabs, so you wont know by hand your hitting the right note?
Don't know how you've been doing it up until now (maybe your method has worked so far) but really you do need a torque wrench and the big arse socket to fit over the dome nut?
#9 MiniBonkerz
MiniBonkerz
  • 1,893 posts
Posted 16 February 2010 - 11:03 PM
would halfords do one could go there first thing in the morning ?
#10 Kam
Kam
  • 4,140 posts
Posted 16 February 2010 - 11:28 PM
I got mine from minispares CLICKY as I wasn't sure if halfords had enough imperial stuff there?
Its the 1 1/2 inch or 38mm incase you do find one, but make sure its about 3 inchies or 80mm in depth, otherwise you wont be able to fit the torque wrench over it as the end of the pin (thread section) will hit. I'd imagine at this size they would be quite deep anyway?
Hth
#11 998dave
998dave
    998cc's Of Dave Goodness
  • 4,566 posts
  • Name: Dave
Posted 17 February 2010 - 08:44 AM
Torques;
Print a copy and keep in your toolbox.
Dave
#12 lrostoke
lrostoke
  • 6,923 posts
Posted 17 February 2010 - 08:58 AM
Its best to use the proper torque, the ball cup can crack if you overtighten the nut.
#13 imvarma
imvarma
  • 153 posts
  • Local Club: Tatsu
Posted 17 February 2010 - 09:00 AM
Just what I needed! Thanks.
#14 GraemeC
GraemeC
  • 7,451 posts
Posted 17 February 2010 - 09:06 AM
1.5" Ball Joint socket - should be available from Halfords.
Note - it is NOT 38mm - an accurate 38mm socket may not fit.
