How To Stop Balljoint From Spining
15 replies to this topic
#1 josh.evans
josh.evans
  • 1,439 posts
Posted 16 February 2010 - 10:50 PM
I have got this 1 ball joint nut to tighten up and i cant as it just keeps spinning i have tried jacking the car up on the lower arm any ideas please help!!
cheers
josh
#2 me madjoe 90
me madjoe 90
  • 1,238 posts
  • Local Club: Fylde Mini Club
Posted 16 February 2010 - 10:53 PM
cheers
josh
Mole grips but it will knaker your rubber boot.
copper slick your thread up nicely
Oh and if your using new lock nuts, They dont need to be overly tight.
Edited by me madjoe 90, 16 February 2010 - 10:55 PM.
#3 bmcecosse
bmcecosse
  • 9,699 posts
Posted 16 February 2010 - 11:11 PM
Jack it up even higher! Then thump the arm with a hammer - to seat the taper. But do check the thread on pin and taper are not damaged.
#4 josh.evans
josh.evans
  • 1,439 posts
Posted 16 February 2010 - 11:18 PM
what size are the bolts for the ball joints? as i got a feeling it could be that a bit knackard?
cheers
josh
#5 jaydee
jaydee
  • 8,565 posts
Posted 16 February 2010 - 11:19 PM
Thats the joy of balljoints LOL
try a jack under the bottom arm, turn the hub then jack it a bit higher, then you should be able to tighten the upper balljoint nut..
#6 josh.evans
josh.evans
  • 1,439 posts
Posted 17 February 2010 - 11:06 AM
its 1 of the bottom ball joints
josh
#7 mk3 Cooper S
mk3 Cooper S
  • 5,569 posts
Posted 17 February 2010 - 11:35 AM
Will the nut go on by hand when not fitted to the car?
Sounds lile the thread is damaged and needs cleaning up or you have the wrong nut.
#8 josh.evans
josh.evans
  • 1,439 posts
Posted 17 February 2010 - 11:40 AM
i havent really tried that but the nut will go so far on the ball joint then just stop and the ball joing starts spining? any 1 have the size of the ball joint nut??
cheers
josh
#9 mk3 Cooper S
mk3 Cooper S
  • 5,569 posts
Posted 17 February 2010 - 11:43 AM
If the thread is undamaged then it defo sounds like the wrong nut.
Is it the same one that you removed from it?
#10 josh.evans
josh.evans
  • 1,439 posts
Posted 17 February 2010 - 12:31 PM
yeh its the 1 i removed from it. do you know the size so i can buy a new 1?
cheers
#11 icklemini
icklemini
  • 2,982 posts
Posted 17 February 2010 - 01:18 PM
I should have some of these in my workshop.. am in Northampton too...
#12 josh.evans
josh.evans
  • 1,439 posts
Posted 17 February 2010 - 01:50 PM
hi where abouts in northampton are you?
cheers
#13 MiniBonkerz
MiniBonkerz
  • 1,893 posts
Posted 18 February 2010 - 09:03 AM
dont know if you have sorted it mate but the nut size is 11/16 plain nut not a nylock
#14 josh.evans
josh.evans
  • 1,439 posts
Posted 18 February 2010 - 09:56 AM
is it not 7/16" ??? this is what minispares told me?
cheers
#15 GraemeC
GraemeC
  • 7,439 posts
Posted 18 February 2010 - 10:41 AM
It is 7/16" UNF
