998 Turbo Project
7 replies to this topic
#1 Tinkerbelle
Tinkerbelle
  • 246 posts
  • Local Club: Tyred and Exhausted
Posted 17 February 2010 - 09:42 AM
Hello all,
I have decided to replace my 1275 in my 1986 City E, with the original modified 998 (c. 65hp) for something to do. I want to get the similar type of output as the 1275 (c. 80-85bhp) so have decided to go for the turbo option.
1) My research has found that a T2 Garrett turbo from a R5GT is best for the A series with Mirage manifolds etc. Is there anything smaller or newer technology that will work better to reduce lag as I suspect I won't need much boost as I am going for moderate power gains.
2) I currently use a Megajolt for ignition and would like to go full EFI on the new build. Am I insame, will this be too much for a hobby mechanic (I'm do have an Engineering Masters Degree for what its worth)
3) Should I consider a supercharger instead?
4) Is a Plenum chnager necessary (I would guess so with the injection requirment)
Matt
#2 Prawn
Prawn
  • 938 posts
Posted 17 February 2010 - 09:59 AM
With regards to turbo choice, I'd very seriously look into the garret GT1752, it's a small ball bearing turbo, with far far less lag than a T3, and I'd imagine less than a t2.
As far as injecting it goes, I think to do it properly you'd need to use something like megasquirt ms2 with the siamesed code.
take a look on turbominis, there's a LOAD of info over there about 998 turbo's and EFI.
#3 John H
John H
  • 768 posts
Posted 17 February 2010 - 10:07 AM
The GT1752 is actually a journal bearing turbo. It is just of much more modern design that the old T series.
#4 Tinkerbelle
Tinkerbelle
  • 246 posts
Posted 17 February 2010 - 10:38 AM
Thanks,
I had a look at the miniturbos site, its like an encyclopaedia on turbo minis.
The boss is at a meeting so I know what I'm doing instead of work for the rest of the day:)
Matt
#5 project mini chris
project mini chris
    have a break, have a...
  • 1,894 posts
Posted 17 February 2010 - 10:41 AM
Thanks,
Matt
:D
#6 Wil_h
Wil_h
  • 3,244 posts
Posted 17 February 2010 - 01:28 PM
The GT17 is no use for a moderatley powered 998. It's boost threshold is only marginally better than a Metro T3 on a 998. The T2 is a far better choice.
I'm currently building a 998 with an IHI RHF4, on paper very similar to the T2, but slightly more efficient.
Other opions are GT15s either 44 or 48, not been tried on a 998 as far as I know.
#7 John H
John H
  • 768 posts
Posted 17 February 2010 - 01:32 PM
You would be wise to listen to Wil.
Him and his brother are the small bore turbo guru's IMHO.
#8 garrett3
garrett3
  • 1,412 posts
Posted 19 February 2010 - 11:46 PM
Its a good conversion to carry out, well worth the effort
Edited by garrett3, 20 February 2010 - 09:59 PM.
