Oil Cooler Thermostat
BenH
, Feb 17 2010 03:35 PM
9 replies to this topic
Posted 17 February 2010 - 03:35 PM
Hi again.
may be me being silly but how do you fit the oil cooler thermostat,
Because i thought youd fit it between the cooler and the block (is this right) but the thermostat has 4 connections on it so what are the leftover 2 for?
Thanks in adavance
Thanks in adavance
Posted 17 February 2010 - 05:55 PM
i am trying to work out how to fit an oil cooler thermostat.
The one from mini spares has 4 pipes 2 are for the cooler what are the other 2 for
http://www.minispare...ty=pb&pid=35270
Posted 17 February 2010 - 06:04 PM
how weirds that iv just posted the same question.
Posted 17 February 2010 - 07:10 PM
Oil from engine and oil to engine perhaps?!
Posted 17 February 2010 - 07:32 PM
If it only had 2 connections it would stop the oil reaching your engine when it's cold. One side goes in the line to the cooler and the other side in the return, the oil is diverted through the stat housing until it gets warm when the stat redirects it through the cooler.
Posted 17 February 2010 - 07:59 PM
ahhh i see!
thats me being silly. i thought you would just cut one of the hoses and fit it inbetween! so you use the two hoses supplied with the cooler and hook them up one side of the thermostat and then the hose from the block to the other side of the thermostat then the one that goes to the oil filter.think iv got it aha
Posted 17 February 2010 - 08:09 PM
block outlet -_filter inlet
--------------H
----cooler in_-cooler out
That kinda thing
--------------H
That kinda thing
what about my drawing aha!
Posted 17 February 2010 - 08:10 PM
picture of engines pretty small i think i missed an connected it to the oil sender unit but u get my jist of where it connects!
