Suzuki Lt 80
No replies to this topic
#1 dan_w
dan_w
  • 152 posts
  • Local Club: Not yet!
Posted 18 February 2010 - 02:27 AM
I have a Suzuki LT 80cc quad that I could do with getting rid of, unfortunately I have lost my way of transporting it and therefore have not had any use out of it for about a year and do not see me having any further use from it any time soon.
I am not exactly sure of its year but from what I believe it is an early 90's quad and it has previously been derestricted.
I stripped it all down (with the exception of the engine) cleaned everything up, greased everything and gave it a fresh coat of paint on the frame about a year and a half ago. Fitted a new battery and had a bout an hours riding on it. It ran ok at the time but struggled to tick over once warmed up. I assume it will need the mixture adjusting to get it running ok. I have not touched it since and it has sat under a good cover in my garden since. I guess the battery is flat so will need charging and one of the tyres has a slow puncher so may be flat. (I have not had a look as it still under the cover)
A few pictures from last year are below but please let me know if you want any more pictures or info.
I am looking to swap for any turbo related parts WHY. List of parts I really need are below so any combination of these parts will be considered.
12G940 head
Inlet Manifold
Turbo Carb
Plenum
Intercooler + pipe work
Fuel pressure regulator
Fuel pump
Dump Valve
Dan
The black marks on the arch are just oil and will wipe off.
