Piston Ring Gap Orientation
8 replies to this topic
#1 GreaseMonkey
GreaseMonkey
    Has Ratchet, Will Make Noises
  • 3,663 posts
Posted 19 February 2010 - 02:18 PM
Hi,
I have 21253 +20 pistons which have 3 piston rings
Just wondering which way should the piston ring gaps be orientated before putting it into the block?
#2 Wil_h
Wil_h
  • 3,244 posts
Posted 19 February 2010 - 02:58 PM
There are a few options, but I always space them 120 deg apart if I have 3 rings, the idea is that they are NOT lined up. Ensure the oil ring gaps are not lined up either.
#3 Ethel
  • 26,022 posts
Posted 19 February 2010 - 03:18 PM
There's also a school of thought that the gaps should face the dizzy side of the engine: centrifugal force throws the pistons against the other side of the cylinder.
#4 mk3 Cooper S
mk3 Cooper S
  • 5,569 posts
Posted 19 February 2010 - 03:37 PM
That is what I was taught too.
#5 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 19 February 2010 - 03:50 PM
Or commonly don't put the gap on the thrust side ( which is the rear of the piston/block ), but space them so no gaps are above each other...
#6 Wil_h
Wil_h
  • 3,244 posts
Never heard that. It won't strictly be a centrefugal force though, but I know what you're saying.
I'm just trying to get the reason for doing it in my head i.e. what part of the stroke would it be an advantage to put the gaps away from the dizzy. I'll have to think a bit longer while I knock up a chilli for tea.
#7 Cooperman
  • 23,315 posts
Posted 19 February 2010 - 04:57 PM
I have always set the gaps to be more-or-less in line with the gudgeon pins with the gaps alternatively one side then the other down the bore, including the oil ring rails if the bottom ring has them. It always seems to work fine.
#8 samsfern
samsfern
  • 5,243 posts
Posted 19 February 2010 - 05:32 PM
always opposite each other, example, ring1 at 0 degree, ring2 at 180 degree, ring 3 at 0 degree, and so on
#9 Sprocket
Sprocket
    Great on Injection faults
  • 7,266 posts
Posted 19 February 2010 - 06:29 PM
At risk of getting flamed, I will say that in all honesty it wont really matter as when the engine is running, do you really think that the rings will stay in the same orientation as when they were put in?
Yes, yes, when fitting the rings to the piston, its easy to position then such that the gaps are not directly above one another, but its not as if they have to be perfectly 120 degrees of seperation. They certainly wont stay that way, and there WILL be a point when the engine is running when all the gaps line up
basicaly, if the ring gaps are not below minimum, dont worry about it too much :shifty:
Edited by Sprocket, 19 February 2010 - 06:31 PM.
