Slightly Modified 998cc Engine Carb Help
Posted 19 February 2010 - 09:26 PM
Posted 19 February 2010 - 10:20 PM
Posted 19 February 2010 - 10:27 PM
Posted 19 February 2010 - 10:36 PM
Anywho, if you looking to save a bit of money try nabbing a Vizard yellow book and modifying the carb with slimmed butterfly and spindle. It's quick, fairly cheap trick and works pretty damn well.
That said, twin carbs IN GOOD CONDITION are loverly.
Posted 19 February 2010 - 10:40 PM
Edited by 1977 Loud_Mini, 19 February 2010 - 10:42 PM.
Posted 19 February 2010 - 10:41 PM
...slimmed butterfly and spindle...
can these be bought off the shelf or do you have to modify the originals?
Posted 19 February 2010 - 11:05 PM
Yea i have been thinking of getting Vizards book and doing some modifications. I'm not sure if my rockers are 1.5 or 1.3, because i have looked on google etc and found red ones from i think Minisport at 1.5 and others the 1.3 rockers are red so i don't know which ones i have, they are TITAN. All i know is the car is lumpy at idle and when slighly revved (timing is spot on).
You REALLY should get the Vizard book, you'll love it for anything your thinking of doing in the future. Covers N/A and all aspects of building (right down to bolts and pushrods and which are best) as well as turbos, super chargers and NOS applications.
But, 1.5 rockers as I recall will be a tad too much for a small bore loosing you something like 5~10bhp I recall, I'd have to look it up to be sure so don't quote me on it.
Modify, takes about 60seconds with a saw. The way I did it was buy a rebuild kit and get my eye in on the old parts, then do the new ones. Only real problem I had was the Vizard guide says to use pan head allen bolts. Which my nut and bolt shop had none, so I had to improvise with some washers and orginal screws. And locktight thread locker.
