as title really,
What advantages would be felt from a stage 1 kit on a 998cc?
Eventually i would like to change to a 1380cc but whilst insurance is still high thats not yet possible.
Any help and opinions would be great.
Thanks.
Posted 21 February 2010 - 11:22 AM
Posted 21 February 2010 - 11:28 AM
hi,
as title really,
Thanks.
Posted 21 February 2010 - 11:42 AM
Posted 21 February 2010 - 11:57 AM
Posted 21 February 2010 - 12:11 PM
Posted 21 February 2010 - 12:50 PM
Posted 21 February 2010 - 01:24 PM
Posted 21 February 2010 - 01:29 PM
Posted 21 February 2010 - 06:01 PM
Posted 21 February 2010 - 07:49 PM
I just fitted the Minispares stage 1 kit today and it was the best fitting one that I've ever had out of the box, included absolutely everything required and fitted a dream...
All that's required now is a quick session on the rolling road to finalise the set up..
http://minispares.co...ty=pb&pid=37334
Posted 21 February 2010 - 08:03 PM
Posted 19 July 2013 - 03:13 PM
Sorry to bump an OLD thread but does anyone know if it's worth adding a stage one to a 1275?
Also, minispares says it helps fuel consumption, is this noticeable?
Posted 22 July 2013 - 11:05 AM
I doubt youill get a better MPG, you'll be flooring throttle much more..
Wont make a big difference unless you get an HIF44 to replace the 38mm carb
Remember to service the car prior to fitting
Posted 23 July 2013 - 10:52 PM
Was bog standard 1980 Mini 1000...then - Cooper (12G295) head, Sportex Intake, Hitachi 38 mm carb/K&N, MG Metro cam, duplex timing gears/chains, Pertronix Ignitor, medium bore LCB, Peco single box exhaust...passed emissions tests annually, was up on power over stock 998s, gave 40 miles/Imp. Gal. or a little better...with adjustable suspension, 10"x5" 100+ wheels & A008s was fastest small bore Mini in Giant Slalom at Portland International Raceway (just before 998 came out)...faster than all but 1 Triumph (hot Spitfire) and all but 3 Jaguars on the day.
If I were working a small bore again, I would at minimum look to the small bore, 3 into 1 Supa Pipes in use in Australia. Going for the best, I'd use a Russell Engineering build with oversize pistons, worked head, RE 13 cam, Supa Pipes and have a Cooper S performer with docile manners.
Posted 24 July 2013 - 02:00 AM
GuessWorks, I have the same set up. Just finished installing it. Still need a tune though.
I also did some carb mods. Swapped out to a butterfly with no overrun valve, trimmed the spindle and soldered the screws and trimmed them.
I'll be adding a stub stack later.
Even un-tuned I noticed a big difference. More torque and pick up. I also upgraded the Mechanical fuel pump too.
Mini Dave, The Stage One, on a value basis, is a great affordable upgrade and gives room for further upgrades later down the line. I just wish I had done it sooner.
I have two 1098's in the garage that I was thinking of swapping ( one was completely rebuilt) but I like the results I got with the Stage One. Plus nothing sounds as bad ass as a 998.
It just has that unique growl.
