Fuse
13 replies to this topic
#1 Bluemini
Bluemini
    Mini Doctor
  • 4,436 posts
  • Local Club: Blacktop Bombers
Posted 30 October 2005 - 08:43 PM
Went out in the van tonight, the head lights work fine but I have no rear lights except brake lights and no dash lights. Checked the fuses and the bottom one was blown, so I robbed the second one down as it was the same amperage (20) and it blew again after a second or two, but I also noticed before it blew that the dash lights were very dim.
Anyone got any ideas before I rip the loom out for inspection??
#2 nomininolife
nomininolife
  • 982 posts
  • Local Club: Mini Mates
Posted 30 October 2005 - 09:10 PM
I had that problem. I just jiggled the fuse about and they worked
#3 Bluemini
Bluemini
    Mini Doctor
  • 4,436 posts
Posted 30 October 2005 - 09:12 PM
The fuse has blown, then I tried another and that one blew too.
#4 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 30 October 2005 - 09:15 PM
if you get realy stuck then bring it down here and i will have a look for you :grin:
i'm not to bad with elastictrickery :cheese:
#5 Bluemini
Bluemini
    Mini Doctor
  • 4,436 posts
Posted 30 October 2005 - 09:34 PM
ooo, might have to hold you to that one...
#6 miniboo
miniboo
    Lord of Original Thinking
  • 9,327 posts
Posted 30 October 2005 - 09:46 PM
i would check for loose connections in the boot see if something is shorting to the chassis
#7 Pooky
Pooky
  • 5,691 posts
Posted 30 October 2005 - 10:05 PM
Yeah something's shorting
could be an earth problem too
#8 cowboy
cowboy
    Friend of TMF
  • 2,799 posts
Posted 30 October 2005 - 10:32 PM
rich was this happening before you started welding tonight
have a look to see if you've melted a cable, which is shorting out, i dont think this is an earth problem as this would cause the lights not to work at all
#9 Bluemini
Bluemini
    Mini Doctor
  • 4,436 posts
Posted 30 October 2005 - 11:02 PM
I don't drive the van much so don't know if its only just started or not, but I have checked the wires around were I was welding and they all look to be ok, no melts or anything.
Can anyone say what rating the fuse is for the dash lights/rear lights?
#10 cowboy
cowboy
    Friend of TMF
  • 2,799 posts
Posted 31 October 2005 - 10:58 AM
im sure the fuses are 8amp.
ok i think the best thing to do is to isolate the problem so you know what to fix or change.
unplug the rear light clusters, and then try and see what happens. if they still blow we need to look at the dash, unplug the dash, and see what happens, also have a look at the electrical connections under the scuttle, where the wire's connect to go to the rear of the car, if one's snapped it could be shorting out
ill have a think and see where else to check
catch me on msn later if you like
#11 Bluemini
Bluemini
    Mini Doctor
  • 4,436 posts
Posted 31 October 2005 - 06:38 PM
Ok, I fitted a 35amp fuse and it blew it straight away. Went through all the wiring in the engine bay and it all looks about as ok as mini wiring ever does, so checked the back loom and think the problem may be between the passanger side lights and drivers side. I'm gonna have to take the loom out to see if there is a problem tho :gimme:
So while I'm at it I might as well take the front loom out too and put new connectors throughout and re-tape it all too.
#12 cowboy
cowboy
    Friend of TMF
  • 2,799 posts
Posted 31 October 2005 - 06:41 PM
all over the kitchen floor again hey rich :gimme: :cry:
#13 miniboo
miniboo
  • 9,327 posts
Posted 31 October 2005 - 07:29 PM
If the fuse is blowing straight away there must be a short direct to earth.
And if its only just happened i would say have a look at the areas that you can see without ripping out the loom.
#14 Bluemini
Bluemini
    Mini Doctor
  • 4,436 posts
Posted 31 October 2005 - 08:42 PM
You know it makes sense! :grin:
