Problems Putting My Rubber On!
17 replies to this topic
#1 battleroc
battleroc
  • 135 posts
Posted 21 February 2010 - 09:52 PM
hey guys
i have a new window screen rubber seal for my car (from minispares) as old 1 is leaking
trouble is i took out the old 1 to fit new 1, but after 45 mins of getting 1 corner in, then the middle in, i couldnt get the other top in.....Grrrrrr
it was so annoying i used some lube and water to help and a platic knife....but couldnt get it to fit
so i put original rubber back in and new chrome filler strip.....as if i spent any longer i would of chucked it in the bush it was doing my nut
>_<
my friend said... original mini window screens are thicker & that i might be better to invest in a new front window screen as there slimmer than old 1's and this should easy alloy me to fit new rubber.....is this true?
i was thinking as my old screen is a little scratchy in places i dont mind investing in a screen as its only £30.00, but if i am going to have same problem then its not worth it
or does anyone have any tips to get new rubber to fit?
Edited by battleroc, 21 February 2010 - 09:53 PM.
#2 HARBER07
HARBER07
  • 4,498 posts
  • Local Club: Naaa......
Posted 21 February 2010 - 09:53 PM
HAHAHAHAHAHAHAHAHAHA @ TOPIC TITLE!
#3 Big_Adam
Big_Adam
  • 7,435 posts
Posted 21 February 2010 - 09:55 PM
Nice title, you try sliding it down the shaft?
Anywho, window rubbers. You don't mention HOW your fitting it. I used a load of soapy water and a cake icing tool to get my screen rubber in.
#4 battleroc
battleroc
  • 135 posts
Posted 21 February 2010 - 09:59 PM
cheers guys....thought title might amuse your childlike minds >_<
its the front screen and i put the screen in the rubber 1st, then push it up to the metal lip of car near the roof and work it round with water/lube and plastic knife......done this to back window and went in piece of poo
cant see why it wont work on front?
Edited by battleroc, 21 February 2010 - 10:03 PM.
#5 mark gillan
mark gillan
  • 33 posts
Posted 21 February 2010 - 10:04 PM
The best way to do it is put the rubber on the car first then put the screen in and pull the rubber over the screen bit by bit. Is that the way you did it or did you put the rubber on the glass first?
#6 battleroc
battleroc
  • 135 posts
Posted 21 February 2010 - 10:11 PM
i put the rubber on the screen 1st......
i am going to try next weekend then that way feller, rubber in car and work the screen into it
i thought i was doing it the right way as the rear screen went i so easy like that.... to be honest
CHEERS >_<
#7 danrock101
danrock101
  • 2,478 posts
Posted 21 February 2010 - 10:22 PM
I had that problem then I found some XXLs they're great
#8 lrostoke
lrostoke
  • 6,923 posts
Posted 21 February 2010 - 10:23 PM
I agree rubber on frame first.
Then put bottom edge of screen into rubber and go round and peel the rubber over.
Plenty of lube.
Did mine the other day new screen, and new screens are pretty thick as well I thought'd I'd been given 2 stuck together at first >_<
Does help if you warm the rubber and the fillet strip up, bucket of hot water.
Edited by lrostoke, 21 February 2010 - 10:23 PM.
#9 battleroc
battleroc
  • 135 posts
Posted 21 February 2010 - 10:24 PM
not what i heard, you use water bombs for rubbers ...he he >_<
#10 battleroc
battleroc
  • 135 posts
Posted 21 February 2010 - 10:27 PM
Plenty of lube.
cheers for that info...was a bit nippy today so i will put the rubber in a warm bucket of water 1st
next time will try bottom edge in 1st
#11 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,080 posts
  • Name: Neil
Posted 21 February 2010 - 10:37 PM
Get some strong cord and tuck this into the rubber all the way round with the windscreen in it. Make sure you have enough cord at both ends to get a firm grip and preferably with the ends in the lower middle section of the the windscreen rubber and make sure the rubber is well lubricated.
Lower the windscreen and rubber onto the bottom edge of the windscreen aperture and push down gently to make sure it is seated. To make life easier have some help for this bit, ask your assistant to push in gently on the outside top edge while you carefully pull one end of the cord along ensuring the inside rubber lip is pulled over the windscreen aperture.
Continue doing this until you have pulled all of the rubber over the lip and the cord is out. Job done, to make sure its all seated in gently thump on the windscreen on the outside either with a rubber mallet or your hand. Then fit your plastic spreader section.
Hope this makes sense as this is the way i fit all old style rubber mounted windscreens.
Edited by sonikk4, 21 February 2010 - 10:38 PM.
#12 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 21 February 2010 - 10:42 PM
doing this on a warmer day will help
if you can't do that warm the rubber up with a bucket of hot water
#13 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 21 February 2010 - 11:18 PM
Sonikk4's method with the string/rope is the traditional one I have used several times on cars other than Minis. For whatever reason, putting the rubber on the body opening of a Mini, then fitting the glass to it seems to work better.
There is a FAQ about this on our board. Perhaps it will help.
http://www.theminifo...showtopic=10693
All joking and rude comments aside, "personal lubricant" (akin to your subject title) is an excellent lube for installing the lock strip.
#14 midridge2
midridge2
  • 1,794 posts
Posted 22 February 2010 - 08:11 AM
Doug i am suprised at you, there is a correct method for fitting glass using a claytonrite sp. rubber as the rubber is designed to be fitted to the aperture first and the glass then fitted.
the string method is used on the quater glass on a mini but not on the front and rear screens.
#15 bert998
bert998
  • 2,558 posts
Posted 22 February 2010 - 09:51 AM
im a seal to the body man myself, then pop the windscreen in.
I use a heater (blowing warm air) and leave it slightly ahead of where im working to soften the rubber and make it easier to work with. This is especially good when fitting the fillet strip.
>_<
