Bring Back "you've Been Tango'd Ad"
105 replies to this topic
#46 Scholes2012
Scholes2012
  • 239 posts
  • Local Club: NONE
Posted 25 August 2010 - 09:20 PM
Youtube.
It's alive... SMC have got it started, it seem's that the drive spindle for the dizzy had been thrown in at any angle, (not by me, but I guess when the engine was made to look nice by the person I bought it off) the timing was 120 degrees out if that's possible?
Can't get it dyno'd yet the nearside CV joint that I rushed to finish for L2B has popped out, so they are gonna check that out then call me for the dyno session, hope to get some video and 55-60 bhp?
Edited by Scholes2012, 19 September 2010 - 04:33 PM.
#47 Scholes2012
Scholes2012
  • 239 posts
  • Local Club: NONE
Posted 08 September 2010 - 11:04 PM
A few other little set backs, (this car is cursed) Sleaford Mini centre did the drive shaft but when they tried to drive it onto the dyno the clutch plate was rusted to the flywheel (my fault for leaving it under a tarpaulin in the garden for a year). They freed that off and did the dyno, 48.9 bhp at the wheels and 58 ftlbs torque at 3400 rpm
Youtube.
not exactly a rocket ship but not bad for a standard 1275 i suppose. Then off for the MOT, they pre-checked it and all seemed ok till the tester looked for the VIN plate, seems the previous owner has took it off/replaced panels with it on,
so it was an instant FAIL. These things are sent to try us, what doesn't kill you only make's you stronger.
Edited by Scholes2012, 07 October 2010 - 05:40 PM.
#48 Scholes2012
Scholes2012
  • 239 posts
  • Local Club: NONE
Posted 11 September 2010 - 09:24 PM
Vin plate sorted... MOT'd and tax'd, I am one very happy bunny, drives very well, hugs the bends better than I ever remember and the suspension and camber etc has not been tweaked yet, the head light's are awesome as is the noise it makes, off to Stanford hall tomorrow, see you there.
#49 Scholes2012
Scholes2012
  • 239 posts
  • Local Club: NONE
Posted 13 September 2010 - 11:39 PM
Got to Stanford Hall and back OK, good day out but... didn't have the right breather for the
the clutch housing, the one that is bent to miss the brake servo, so blanked it off, (you know what's coming) think the clutch oil seal has gone because the clutch is now slipping and there is oil coming out the bottom of the housing, (welcome back to Mini ownership).
#50 CaptainBland08
CaptainBland08
  • 675 posts
Posted 14 September 2010 - 01:20 PM
:D mine had the same problem but i got away with not replacing the seal... although i would advise that you do...
#51 Scholes2012
Scholes2012
  • 239 posts
  • Local Club: NONE
Posted 02 October 2010 - 05:41 PM
Stripped the clutch, no prob's getting it off, ordered new seal and fitting tool, I'm a bit miffed that fitting tool was not in stock as it didn't say "out of stock" when i bought it, they sent me the seal and now I'm paying delivery twice,
and it's not in till the 8th.
Bit more play in the primary gear than i would wish for, may order another shim but at £28 seems a bit steep for what it is.
Edit: If you ever decide to re-shim the primary gear, check out wood and pickett 1st £12 inc postage. grrrr
Edited by Scholes2012, 25 January 2011 - 09:10 PM.
#52 Scholes2012
Scholes2012
  • 239 posts
  • Local Club: NONE
Posted 12 October 2010 - 04:12 PM
Finally got the clutch oil seal fitting tool from Mini spares, I suppose it gave me chance to add to the order, it's was so easy to use that it was a bit of an anti-climax when I got the seal fitted, kind of a "is that it" not like the usual 2hr struggle.
Decided to get a 0.120" thrust washer and the rear bush for the primary gear as the bush was fairly scored, got the Mini Spares floating bush again no drama fitting it, and now have 0.005" play in the primary gear not 0.014" that i had before.
Cleaned the pressure plate and flywheel, first with and engine degreaser and dried off with an air gun, then cleaned the friction areas of them with thinners then brake cleaner, think that should be clean enough, had a friction plate from another engine that had only done 26,000 miles so am using that, it still has plenty on it.
Lapped on the pressure plate Boss with fine valve paste, and followed the Haynes manual, again no drama's other than i couldn't get to the lock tab to knock it out, that's as far as got today so will try again tomorrow.
Edited by Scholes2012, 22 October 2010 - 04:52 PM.
#53 Scholes2012
Scholes2012
  • 239 posts
  • Local Club: NONE
Posted 17 October 2010 - 09:31 PM
I couldn't get to the lock tab to knock it out, that's as far as got today so will try again tomorrow.
I ended up using the side of a cold chisel in the slot rather that trying to hit the end of a 5" chisel in a 4" space, worked a treat.
Adjusting the clutch throw out i only had one 24mm spanner and i didn't fancy grinding it down to fit so made this, don't you
just love plasma cutters.
Got around to bending the clutch oil breather.
Dressed the weld.
Prepared for paint.
No blue left so will be silver, same as the clutch housing.
#54 daveeeeee
daveeeeee
  • 684 posts
Posted 18 October 2010 - 10:30 AM
breather looks good :thumbsup:
#55 Scholes2012
Scholes2012
  • 239 posts
  • Local Club: NONE
Posted 19 October 2010 - 07:33 PM
Fitted the breather, it's a bit tight to the brake master cylinder.
Posted ImagePosted Image
Went out for a drive, the clutch work's fine, but had a heavy down pour and with the heater, wipers and lights on think I've blown a fuse as the wipers are now half way up the windscreen.
#56 AndyMiniMad.
AndyMiniMad.
  • 3,295 posts
Posted 19 October 2010 - 08:36 PM
Ahh!! dont you just love minis, no sooner have you fixed one thing then something else breaks. Nice welding on the breather tube.
Edited by AndyMiniMad., 19 October 2010 - 08:38 PM.
#57 Scholes2012
Scholes2012
  • 239 posts
  • Local Club: NONE
Posted 20 October 2010 - 01:29 PM
Was just a fuse, ill have to keep an eye on it, Why do fuses blow, too much current? or dodgey connection?
#58 minimk1
minimk1
  • 917 posts
  • Local Club: a's of herts
Posted 20 October 2010 - 01:46 PM
Like the colour and the breather filter. nice to see another mini being restored
#59 Adcuz
Adcuz
  • 843 posts
Posted 20 October 2010 - 02:17 PM
What a nice project! Soo clean.
#60 miniallsort
miniallsort
  • 4,723 posts
Posted 24 October 2010 - 10:21 AM
very nice
