Engine Bay Clean Up+ Paint
Posted 02 March 2010 - 08:58 PM
Just got my engine out to overhaul and want to tidy up the engine bay. Just been to Hellfrauds to buy some autoglym engine clean. Its doing a good job. Im now in the progress of cleaning all the muck off the engine bay and suframe. I was hoping not to have to paint it, but i really need to...
My car is white, the engine bay bulkhead looks ok, i just need to paint the inner wings, inner front end. What do you guys suggest regarding painting...take the effort to spray it using cans? or just briush paint?
Someone told me brush painting will look rubbish, but then my inner wings arent exactly smooth and in top notch like the outer bodywork. Problem with white is any dirt shows up too easily!
what do you think?
cheers
Posted 02 March 2010 - 09:00 PM
Hi,
what do you think?
cheers
me personaly i would paint brush it wouldint want to get overspray everywere beside brush is easy to get whole subfram and engine bay all the gaps and hard t sray areas brush defo for me pal
Posted 02 March 2010 - 09:06 PM
Posted 02 March 2010 - 09:10 PM
Hi,
what do you think?
cheers
Ive just painted the Engine on Boris with Engine Enamel from Moss
I dont think it looks rubbish
Though i must admit if your going to paint things like the Rocker Cover,Coil etc its best to use an Aerosol with Moss do also in the matching shade as on smaller smoother items the Aerosol give a nicer finsh but the engine block isnt a smooth casting anyhow so Brush on Enamel works well
Huggz
Jodie
Posted 02 March 2010 - 09:15 PM
yeah without a shadow of doubt i shall be painting the engine block with a brush. I will be replacing everything else on the block like coils, alternator...etc.
I think the only other thing i will be painting than the engine bay is the brackets.
Your block looks nice. I think a lick of paint certainly changes the presentation. Im sticking classic red and silver for the engine.
Its just the damn engine bay. Its a slightly different shade of white to the rest of my car. Im going to have fun matching hammerite!
Did you remove everything from the engine first then paint? or do it in sections|im tempted to do it in sections so i dont forget where to put things back lol!
Posted 02 March 2010 - 09:26 PM
You can tell that I brushed the rocker cover if you look closely, but its not that noticeable and I don't really care! As for paint I just used some green engine laquer
Posted 02 March 2010 - 09:31 PM
cheers
Posted 02 March 2010 - 09:39 PM
Check out This Page on my Thread
http://www.theminifo...x...4169&st=195
Yes the Block was stripped of Alternator,Coil,Rad,and the Throttle Body Injection Unit and exhaust manifold from the rear of the Block
Incidentally we have tried to clean the engine previously with Gunk but it was useless
This time we Stripped The Engine With 3in1 Heavy Duty Degreaser from Halfords
Really Good Stuff
We just sprayed it on and scrubbed it off with cheap Asda Dish Sponge Scourers
Check out the thread see how dirty his Block was,how clean it came up and keep an eye of the thread over the next few days to see it all back together
Huggz
Jodie
Posted 02 March 2010 - 11:28 PM
Posted 03 March 2010 - 12:27 AM
You voiced concern about masking the other paint work. It will be easy enough for you to mask the outer wings and you only need a cursory masking of other components. An easy and effective masking technique is to wrap aluminum foil on the parts you want to protect. It is easily formed and can be tucked and folded into places masking paper is difficult to use.
If you don't find the paint you want in rattle cans, consider buying it mixed at a paint shop to your color preference. You can use an inexpensive, single-action air brush to spray sections of the engine bay at a time. If you don't have an air compressor, your spare tire can be a source of air for an air brush. Just refill it frequently at your local service station.
Posted 03 March 2010 - 08:37 AM
