Easiest Way To Install Spot Lights
4 replies to this topic
#1 samperks
samperks
  • 467 posts
  • Local Club: looking
Posted 02 March 2010 - 10:58 PM
want to finally hook up the spot lights on my mini to the main beam, is there a cheap kit i can buy to do this?
any help and advice on the area is welcome
i have 4 spotlights on the front of the mini n come only seem to see sets to set up 2 of them.
thanks, Sam
#2 R1minimagic
R1minimagic
  • 4,660 posts
Posted 02 March 2010 - 11:14 PM
I Pm'd you about this
#3 mk1leg
mk1leg
  • 9,343 posts
Posted 02 March 2010 - 11:20 PM
Here's mine with 4 lights ..........4 on flash/H/beam then a switch to change 2 onto H/beam and 2 on to dip/fog........
here is a diagram for you ......2 spot.......2 fog................
good luck............... <_<
#4 samperks
samperks
  • 467 posts
thank you <_<
#5 chris2009
chris2009
  • 124 posts
  • Local Club: CMC
Posted 02 March 2010 - 11:30 PM
In that diagram is it showing you get the live feed for the relays from the top fuse? i take its the 4 glass tube type fuses
