Pipercross Airbox Help.
2 replies to this topic
#1 mickyh
mickyh
  • 391 posts
  • Local Club: not yet
Posted 03 March 2010 - 10:48 PM
hi, i recently bought a pipercross air filter to replace the stand 1275 spi airbox, only down side is i have come to fit it and the instructions are very bad, i just need to no how to put it together and where the lamber sensor and the hose goes on to the pipercross filter can anybody help me.
thanks mike
#2 mickyh
mickyh
  • 391 posts
Posted 04 March 2010 - 09:17 AM
thanks mike
bump
#3 The_Mistro
The_Mistro
    Farmer Barley Mow
  • 2,369 posts
Posted 10 May 2010 - 02:00 PM
ok, the lamba sensor is on the exhaust manifold, i think you are talking about the air flow sensor?
if you take the air box of the injector, and remove the sensor that is bolted on it, and put this on the pipercorss in one of the two small holes and then tighten in place, obviousy reconnect the sensor, the other hole there is a rubber bung, put this in the other hole and then it is ready to bolt to the injector with the seals!!
the red hose needs to be sealed with a self tapper, and there shouldnt be any others left on the engine!
attatch the air filter and your away!
