Brake Fuild Loss?
11 replies to this topic
#1 jonti1275
jonti1275
  • 14 posts
Posted 04 March 2010 - 04:05 PM
Hi, I have a brake fluid leak but cannot find out whrer it is going. I had checked the front and rear brakes and all it fine and dry, I have checked all the pipes and these are fine. I have checked under the bonnet and threr are no leaks tho be found?.
I had left the car stored over the winter but went to take it out and found the fluid res bone dry?. So i checked under and around the car before moving it and there is no evidence of fluid any where.
Is it possible the master cylinder is filling up the servo? (green tag master cylinder)The servo has rust on it below the mou nting point of the master cylinder.
Has anyone else suffered the same problem? Can anyone help please? Any thoughts?
All advice greatfully received.
My car is a 2000 cooper sport mpi standard brake system
Cheers.
#2 cambiker71
cambiker71
  • 1,050 posts
  • Local Club: Cambscustomclassics.com
Posted 04 March 2010 - 04:18 PM
If there's definitely no external leaks then i'd suspect the master cylinder as you suggest, out of interest did you check the level before parking it up? My thoughts are it may have been leaking somewhere leaving the level low. Have you had the rear drums off to check inside? If not then try that before spending any money.
#3 jonti1275
jonti1275
  • 14 posts
Posted 04 March 2010 - 04:31 PM
I have had the drums off they are fine all dry and pistons are ok.
When the car was put away it was had fluid in. but the resvoir is now totally empty. I checked it about 5 weeks ago and it had gone down a little.
I can't think it would go anywhere else. I have not removed the master cylinder yet thats where i will go next i think.
#4 Jay3178
Jay3178
  • 170 posts
  • Local Club: Abingdon Mini & South Central
Posted 05 March 2010 - 03:11 PM
mate of mine was loosing brake fluid through the vacume pipe on the inlet manifold, the seal in the servo had deterioated and the vacum from the engine gradualy just sucked it dry. the fluid did make it smoke a tad which gave it away a little :) this was from a 1998 cooper, so may be worth checking the vacume pipe on the inlet manifold
#5 jonti1275
jonti1275
  • 14 posts
Posted 09 March 2010 - 09:29 AM
I have removed the master cylinder and found a resevoir of fluid in the front of the servo!
And yes it was just about sucking it throught the pipe aswell.
Thing i brought a seal kit for the cylinder and the end seal and circlip don d'not fit as it has a three pronged round clip instead of the last seal and circlip?.
Is this right or where they changed late on in life. The seal kit i brought is the right one.even the haynes manual shows the haynes manual shows the seal and circlip?.
Has anyone else come across a different arrangment
#6 stevede
stevede
    As seen on TV
  • 1,164 posts
  • Local Club: None
Posted 09 March 2010 - 10:05 AM
Did mine last night.
I have the green tag master clyinder and used the GRK1032 kit bought from Mini Sport.
Everything fitted a treat.
I had to remove the springs & metal clips to get the seals on.
The rear most seal was a pain as you have to compress 2 springs before pushing in the 2 rear most seals before the circlip.
Not sure if we're on the same part, but mine had a plastic tabbed washer type part in between the 2 largest rear seals.
Have you a picture of the parts you have (new & old)
Let me know if I can assist
Steve
Steve
#7 jonti1275
jonti1275
  • 14 posts
Posted 09 March 2010 - 08:03 PM
I had a look at a new one today and it is the same as mine, so at some point rover did away with the last seal and washer and circlip.
This means the service kit is not strictly correct but i will fit the cylinder and see what happens.
This is a view of the cylinder nylon seal Attached File  IMG_2262.JPG   80.9K   12 downloads
Edited by jonti1275, 09 March 2010 - 08:20 PM.
#8 stevede
stevede
    As seen on TV
  • 1,164 posts
  • Local Club: None
Posted 09 March 2010 - 08:35 PM
Mine had a similar but lower profile plastic washer in between the 2 large seals that go at the rear. Then a metal washer and finally the circlip.
When you look at the back of mine, you just see the circlip & washer.
#9 rolf
rolf
  • 68 posts
Posted 10 February 2013 - 09:34 PM
I have the same exactly.
How do I open this without making any damage to the seal?
#10 Ipod
Ipod
  • 2,024 posts
Posted 10 February 2013 - 10:09 PM
Edited by Ipod, 10 February 2013 - 10:12 PM.
#11 rolf
rolf
  • 68 posts
Posted 11 February 2013 - 07:41 AM
Haha!
You may have not answered to my question, but you made me laugh.
Thats something!
#12 rolf
rolf
  • 68 posts
Posted 12 February 2013 - 02:51 PM
by the way, you look good in the picture!
