Stub Stack In K&n Filters Do They Make Much Difference?
16 replies to this topic
#1 freshairmini
freshairmini
  • 1,718 posts
Posted 04 March 2010 - 06:37 PM
Hi
Ive got a 1990 1275 cooper and was wanting to update and improve the carb. So the first thing i thought of doin was getting rid of the normal air box and fitting a K&N filter. When i was reading about them I came across a stub stacks.
what I wanted to know is what they do, and if they improve the performance, aaand do they fit between or inside the K&N conical filters??
heres the filter...
http://www.knfilters...px?Prod=56-9330
and the stub stack
http://www.minispare...=...B STACK 1.5
can any one help/advise??
thanks
#2 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 04 March 2010 - 06:41 PM
get your self a copy of Visards yellow bible ;)
#3 Big_Adam
Big_Adam
  • 7,435 posts
Posted 04 March 2010 - 07:18 PM
Filter makes you faster,
Stub stack shuts it the hell up slightly.
For more details see Bungle's post.
#4 samsfern
samsfern
  • 5,243 posts
Posted 04 March 2010 - 07:22 PM
stub stacks help to improve the airflow into the carb, thus improving performance slightly, im not sure how theyll work with a k&n though.
I run short ones on my carbs and use filter socks.
#5 Pooky
Pooky
  • 5,691 posts
Posted 04 March 2010 - 07:50 PM
I doubt you'll ever notice the improvement but that's not to say it isn't there ;)
Every little helps!
#6 davejf
davejf
  • 280 posts
  • Local Club: CV1 and Central Minis
Posted 04 March 2010 - 09:44 PM
Not sure about those ones, but decent ones should help. I'm planning to find out in a few weeks when i have my car re-tuned i'll be getting them to compare without and with some that i've had made to fit in my K&N cone filters.
Dave
#7 Surfbluegarage
Surfbluegarage
    AKA mini_mad_daps
  • 1,547 posts
Posted 04 March 2010 - 09:54 PM
stub stacks help aid airflow like stated above. when air enters the carb it goes through the filter into the mouth of the carb.. only problem is that air doesnt like sharp edges it prefers smooth radii. vizards done a helll of alot of research into the lenght and shape of stub stack for most carbs so id sugeest fitting one.
#8 mini_mad69
mini_mad69
    Let future you worry about it
  • 5,417 posts
  • Local Club: urrrr no
Posted 04 March 2010 - 09:58 PM
Stub stacks are good, longer ones give more torque I think, but the longer it is, you will probably need a longer air filter to give enough flow.
#9 freshairmini
freshairmini
  • 1,718 posts
Posted 05 March 2010 - 09:09 AM
get your self a copy of Visards yellow bible :cry:
Visards yellow bible?? what is that :)
#10 R1minimagic
R1minimagic
  • 4,660 posts
Posted 05 March 2010 - 09:15 AM
Tuning bible for A series engines, very in depth in most areas with power charts etc etc
#11 Ethel
  • 26,027 posts
Posted 05 March 2010 - 09:29 AM
Since Tuning BL's A-Series Engine will set you back more than the stub stack I'll tell you that a stub stack is worth 5-6% better airflow over a bare carb, that's better than any ram pipe.
The book is well worth the money all the same.
#12 davejf
davejf
  • 280 posts
Posted 05 March 2010 - 05:27 PM
This is what i'm planning to fit, will see what difference it makes after the rolling road session.
#13 ansmania
ansmania
  • 13 posts
Posted 01 July 2022 - 12:39 PM
So did you fit it in the end? Where did you buy it?
#14 stuart bowes
stuart bowes
  • 2,208 posts
Posted 01 July 2022 - 02:18 PM
OP was last active Sept 25th 2014
that's not to say others won't be able to give you info obvs.
Edited by stuart bowes, 01 July 2022 - 02:19 PM.
#15 Turbo Phil
Turbo Phil
  • 2,426 posts
Posted 01 July 2022 - 06:17 PM
https://www.theminif...hl= stub stack
Phil.
