Mk 1 Styling
Posted 04 March 2010 - 10:40 PM
before i went ahead with it i wanted to check if i would have any problems fitting the earlier grille in my later model mini??
Also i was wondering where is best to mount the grille buttons as my front end only has 1 bar in the grille opening. is it posible to fit the grille buttons on the end of the grile instead of the middle??
pictures of others would be a good help aswell, if possible
cheers, Rob.
Posted 04 March 2010 - 10:43 PM
Edited by Mr. Bridger, 04 March 2010 - 10:43 PM.
just doesn't seem it would look right.
also will have to grind the lip of your standard bonnet to make it look mk1 style and to also allow the use of the 1 peice grille
Posted 04 March 2010 - 10:53 PM
would it not look right as the buttons would be at the sides of the grille? or because they will ruin the retro look?
cheers for your replies!
Posted 05 March 2010 - 12:46 AM
Did you want to put them like that, or further to the sides?
Posted 05 March 2010 - 09:27 AM
Posted 05 March 2010 - 09:30 AM
that is the look i want to go for, i just didnt know if the grille buttons could be mounted that wide as i have seen many where they are mounted nearer the middle.
anyway, cheers for the help!
Posted 05 March 2010 - 09:35 AM
Posted 05 March 2010 - 10:26 AM
Your current bonnet will have the top part of the grille attached to a lip on the front of it. The Mk1 grill doesn't have this, so you'll either need to remove it or get a new bonnet intended for Mk1 cars.
It's better to use a van bonnet as it had no lip and the bonnet hinges in the right position, if you use a standard MK1 bonnet the hinges will be in the wrong place, just thought i'd add for reference in case anyone reads this later.
