hey everybody. does anyone have any knowledge on dellorto carbs.I bought a dellorto dhla 45 off a chap on here but a bit confused abou all the different connections fuel line is obviously on top of the carb but what are the onnections on the inlet manifold and where do they go to? one is to fit a banjo bolt anline and anotheto to fit a pipe on the end of? ANY HELP PLEASE?
Dellorto
willg81
, Mar 09 2010 08:37 PM
2 replies to this topic
Posted 09 March 2010 - 08:37 PM
Posted 09 March 2010 - 08:58 PM
The connections on the manifold will be for vacuum. Normally you will have a larger one for Brake Booster and that is all. If there is a smaller line it may be for vacuum advance on the distributor - but often this is blanked off when using a weber/dellorto.
Posted 09 March 2010 - 09:03 PM
brilliant ok thanks where do i need to run it off to then?
