Posted 11 March 2010 - 06:16 PM
As said what colour are the plugs? Are the plugs getting a spark? Is the engine properly turning over or is it not getting that far? (In which case look at battery/starter motor).
If you are sure the battery is fine test for a spark at the plugs (take them out and hold them to the block, and get someone to turn the key. make sure you don't get in the way of it as it bloody hurts though) If there is no spark then look towards a problem with the HT and master leads, if new ones don't help try a different coil.
If you are getting a spark and the battery is fine but its struggling to turn over, smack the starter with a big spanner, or try another starter motor.
If it's turning over but not starting, it's beginning to look like fuelling. Check the colour of the plugs, and adjust the mixture on the carb accordingly. turn a flat at a time and try for a decent amount of time. If no luck, turn another flat and try again etc etc etc. Or your carb could need a clean, it's not unusual for the piston to get jammed on some grit etc. Use the haynes manual and take it apart, clean it, put it back together and try again.
Other stuff to take into consideration: plug electrode gaps, dizzy points gap, dizzy condenser, dizzy rotor arm, dizzy points, dizzy advance, timing, are the cylinders firing in order?
When you get it running, get a CO tuner/colortune, and get it running sweet.
It's a bit trial and error and it's a pain but it gets there. I had to do it and found, after replacing a hell of a lot, my carb was proper buggered. Got a second hand one and tuned it up and off I went again. A bit later had similar problems, took the carb apart and found that the piston was getting stuck.
Good luck
