Seized Clutch
2 replies to this topic
#1 micrawavewindow
micrawavewindow
  • 609 posts
Posted 12 March 2010 - 10:21 AM
i have just happened upon a mini 35 with a seized clutch asin it wont engage any gears but there is fluid how can i fix this
#2 IainR
IainR
  • 251 posts
Posted 12 March 2010 - 12:25 PM
If the clutch will not release, one solution apparently is to support the front on the car on axle stands, start the car in gear and then bang on the brakes.
It didn't work on mine, after a few attempts I felt it was going to damage something else, so I bit the bullet and replaced the clutch.
If you do manage to set it free by the method above, the clutch housing is likely to be full of clutch plate dust and will probaly clog up the starter if you have an inertia type.
#3 bmcecosse
bmcecosse
  • 9,699 posts
Posted 12 March 2010 - 04:02 PM
If it's just the operating lever that is stuck - pour boiling water over it - and soak it in release oil!
