Background Ive just changed my clocks from two to three cluster, in doing this i bought a second hand 3 clcok cluster then swapped the printed circuits over and attached the rev counter to my 2 clock cluster simples
Before i did this i tested both units and they worked fine. the bulb does work as i've swapped it around
Interesting bit is the cable block at the back all the wires are corrected and don't appear to be loose also the printed circuit appears fine bearing in mind they all worked moments ago.
When i was having a bit fiddles i left the main beam on and tried removing the cable block as i did the bottom two warning lights went out and the main beam one flickered on
I took this to mean the circuit wasn't making enough contact with the block so i bent it back over itself so the cable block actually pushed up against the circuit but nada.
Any suggestions
