1989
998 Mayfair Auto
im having problems with my carb setup, the car idles & accelarates fine when running on the choke, but once the choke is off the idle speed decreases and when i try to accelarate the engine just splutters then dies
ive tried changing the air/ fuel mixture on the carb but this seems to have no effect.
when i make it run rich it spluttes then bilds up revs but still spluttery and unstable, and the leaner i make it run it just splutters then dies.
i recently fitted a stage 1 exhaust system with new inlet & outlet manifolds and the kit came with a AAU needle which i havent used as i thought it would make it use more fuel.
can anyone help?
Carb Problems :(
gdl1986
, Mar 13 2010 10:11 PM
3 replies to this topic
Posted 13 March 2010 - 10:11 PM
Posted 13 March 2010 - 10:15 PM
The AAU needle will make it use more fuel but that's because it'll need more fuel! What air filter are you using? K&N cone? Filter element?
Try it with the AAU needle (that's what I was using after I fitted my stage 1).
You'd be best going for a Mini friendly rolling road tune as they'll be able to give you and/or tweak a needle to be perfect for you. They'll also set up your timing. Have you even checked your timing?
Posted 13 March 2010 - 10:19 PM
as far as i know the timing is fine but i'll try the AAU needle to see if thats the problem
thanks.
thanks.
Posted 13 March 2010 - 10:28 PM
oil in dashpot?
mine kep doing that and after taking it to specialist it was just simpe case of putting more oil in it
