Gaz Shocks
8 replies to this topic
#1 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 14 March 2010 - 07:58 PM
Im looking to buy a set of these Gaz shocks with a set of hi los.
Which ones should i get the lowered ones or the standard height, i dont really get what the difference will be? Im i mising something or am i of my rocker?
#2 Austin
Austin
  • 348 posts
  • Local Club: Minis 'n' Oatcakes
Posted 14 March 2010 - 08:03 PM
The lowered ones are shorter, it really depends how low you want your mini.
#3 nicksuth
nicksuth
  • 1,631 posts
Posted 14 March 2010 - 08:04 PM
Depends on the type you buy some makes are about 15mm shorter and some can be 25mm shorter (shorter = length of stroke and overall length when fully extended), for HiLo's use shortened type.
taken from Minispares website ---------
The closed length of front adjustable dampers from bush pin centres is as follows
Gaz standard height 230mm and lowered 215mm
Spax standard height 235mm and lowered 220mm
Koni standard height 225mm and lowered 215mm
AGX evolution in standard height only 210mm
see full article (you may need to register with them for access?)
http://www.minispare...x?ty=ad&aid=234
#4 Pooky
Pooky
  • 5,691 posts
Posted 14 March 2010 - 08:07 PM
Should the different top shock mounts be fitted as well?
#5 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 14 March 2010 - 08:10 PM
so the standard height ones are fine to have even if lowering the height with the hi los?
edit . cheers for the pointer nick
Edited by minisilverbullet, 14 March 2010 - 08:16 PM.
#6 Austin
Austin
  • 348 posts
Posted 14 March 2010 - 08:14 PM
Yes, but they will restrict how much you can lower the car by, as too much will mean that they bottom out. If you are going to lower it by more than about 1"-1 1/2" then lowered/shorter ones would be best.
#7 Nick Warwick
Nick Warwick
  • 1,588 posts
Posted 14 March 2010 - 08:51 PM
get the shorter shocks if you are wanting to go low and have them work, i have them and can say they are a nice ride
#8 Jackamilf12
Jackamilf12
  • 236 posts
  • Local Club: HAMOC
Posted 14 March 2010 - 08:59 PM
do lower shocks lower your car?
i recently brought some shocks that claimed 20mm lower? i wasnt sure wha this meant either?
cheers
Jack
#9 reffle
reffle
  • 80 posts
I suggest the lower ones, my car isn't lowered and the shocks bottom out with the standard height Gaz.
