Oops Exaust Came Off
Posted 15 March 2010 - 11:16 PM
Posted 15 March 2010 - 11:19 PM
not sure about welding though.
get some of the double style clamps from minispares and just make sure the bolt ends of the clamp aren't facing straight down otherwise it could happen again
Posted 15 March 2010 - 11:32 PM
ive done the exact same thing before man don't worry
Thanks for that. I live in new Zealand and order from minisports australia is there a particular name for them.....stupid question I know but just starting out on my long fruitful journey with these great cars
Posted 15 March 2010 - 11:33 PM
Posted 16 March 2010 - 12:33 AM
Edited by GTIAlex06, 16 March 2010 - 12:33 AM.
Posted 16 March 2010 - 11:58 AM
Now, I build a few rally cars and one thing you can't have is the exhaust coming off on rough roads. So I weld the Y-piece to the exhaust pipe, then clamp the 2-ended end of the Y-piee onto the down pipes with good quality clamps, making sure the clamp ends are either horizontal or vertically upwards, not downwards. As an additional fixing I drill and tap 1/4" unf holes through the 2-layers of pipe and the clamp and fit short 1/4" unf bolts through the joints actually into the pipe itself.
With additional clamps and fixings at the back the exhaust is very secure.
Posted 18 March 2010 - 11:43 PM
If you weld at the 2-into-1 location you'll never be able to remove the manifold without sawing through it!
Thanks for that I think that is where the weld is going to go at the y piece to the exhaust. Will do me for a while. Hopefully when money less tight looking at new exhaust system...... thinking stainless steel
