Installing locks
10 replies to this topic
#1 Dom
Dom
    Moved Into The Mazda
  • 10,685 posts
Posted 05 November 2005 - 08:16 AM
How do I remove my old door barrels and boot barrel to replace with the new ones I have just purchased?
#2 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 05 November 2005 - 12:14 PM
first you need to remove the handle ( or boot lock ) from the car, then you'll find there's spring clamp washer on the end, remove that but keeping an eye on where it shoots off too as you'll need it..
Insert the original key, and the lock will just drop out...
Refitting is reversal of above procedure :cheese:
#3 Dom
Dom
  • 10,685 posts
Posted 05 November 2005 - 12:37 PM
Thanks. :thumbsup:
#4 YoungUn
YoungUn
  • 488 posts
  • Local Club: F.A.B.M.O.C
Posted 05 November 2005 - 11:42 PM
I need to fit new ones too because my mum lost my keys... i have removed my door locks but how do you remove a locked boot handle
sorry for hijacking this post
charlie
#5 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 06 November 2005 - 08:10 AM
It's not easy without the key, but the bestway maybe to drill the lock tumbler out..
*edit*... sorry read post again, the boot is locked shut :nugget:
If you are lucky, you may be able to undo the hinge bolts, of the car has not been repaired, it's likely that the bolts on the inside are covered with seam sealer which will prevent them from moving when you try and undo the bolts... failing that you could drift out the pin which holds the two parts of the hinge together....
Other ideas are the rear parcel shel has holes in it and if you have skinny arms, you maybe able to get to the bolts for the lock that way...
Edited by GuessWorks, 06 November 2005 - 08:15 AM.
#6 mini-mad-dan
mini-mad-dan
  • 467 posts
Posted 06 November 2005 - 09:35 AM
Can't you get locksmiths for car doors if you have proof of owneship?...................just a thought
#7 1984mini25
1984mini25
  • 8,785 posts
Posted 06 November 2005 - 10:57 AM
OR the way I got the locks off my 2nd hand doors :thumbsup:
Try hammering a flat-headed screwdriver in the lock
And if it fits tightly enough u should b able to open the boot :huh:
Does mean that the lock barrel will be fcuked
u could but there r 2 screws that are hiddern when boot is shut :thumbsup:
#8 YoungUn
YoungUn
  • 488 posts
Posted 06 November 2005 - 11:38 PM
will the screwdriver technique work for the petrol cap too ?
thanks guys, Charlie
#9 1984mini25
1984mini25
  • 8,785 posts
Posted 06 November 2005 - 11:48 PM
yep might do
will have to get a new petrol cap
prob best not to do this
as u may end up with bits falling into the tank and blocking fuel lines
#10 YoungUn
YoungUn
  • 488 posts
Posted 06 November 2005 - 11:58 PM
i need to buy new locks anyway so that i have one key for the doors and boot, didnt like when i had 3 different keys
charlie
#11 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 07 November 2005 - 05:22 PM
I'm sure Mini keys changed after the Mk3... but the early cars had some very, very, rudimentary profiles with only a few pins. It wouldn't take much to pick them. I'm sure a local lock smith could unlock them for you. Once unlocked they would be replaced as mentioned above. Since you're talking about replacing them, I don't think drilling them out is such a bad option. The screwdriver option is a bit riskier as you are still looking at a lot of prying and high-torque twisting to free the lock core. You stand the risk of doing some serious panel damage along the way.
There are matched key/core kits available from places like MiniSpares. I re-keyed my car so I only have one key that unlocks everything. However, common key lock sets for Mk1/2 cars are NLA. I had to buy a Mk3 set and machine the lock cores to fit my ignition and door handle. It was a bit of work but well worth it to only have one key to worry about.
