I need some advice with oil pressure on the hayabusa.
The manual says you should get between 28-71psi at 3000rpm with oil at 60deg.
At 3000rpm I get nearly 100psi when oil is cold.
25-30psi at 60deg.
but when the oil gets hotter i.e. 80deg the pressure is down to about 15psi at 3000rpm.
Is this too low??
Hayabusa Oil Pressure
Gsybeach
, Mar 19 2010 04:13 PM
4 replies to this topic
Posted 19 March 2010 - 04:13 PM
Posted 20 March 2010 - 04:11 PM
wheres your oil cooler sounds like you may be getting it too hot and thinning due to overheating
chris
chris
Posted 20 March 2010 - 04:36 PM
The oil cooler is enclosed near the engine but it has air fed to it from a naca window duct. Admittedly I was driving at the local speed limt (35mph) at the time so not much airflow was going through it.
The oil temp gauge only read 80degC, which I don't think is that high? It would be interesting to know what pressure others are getting at 3000rpm/oil temp 60-80degC?
Posted 21 March 2010 - 05:08 PM
I have just checked the oil I am using and it is 10W-30. Could this be the reason? Maybe a straight change to 10W-40 would increase the pressure.
What viscosity oils are you using??
Posted 22 March 2010 - 10:45 AM
10W30 is a very thin oil when hot.
