Oil In Fan
Posted 20 March 2010 - 11:19 PM
Posted 20 March 2010 - 11:25 PM
- back plate gets pushed away from the block due to too long screws
- the rivet that closes the oilway in the head is leaking
Posted 20 March 2010 - 11:49 PM
Edited by jonny d, 20 March 2010 - 11:54 PM.
Posted 21 March 2010 - 04:02 PM
Thanks for replying which screws would be to long and what rivet in the head would make it run down the flange and where do i look for the leak can i see it from the thermostat end I only used the screws that came with the cover but i did notice that one of them was slightly shorter where should I have used that one
The screws that hold the cover. If you put oo long ones in (on the top), they push the plaste (&cover) away from the engine, causing a leak.
The rivet is behind the thermostate housing, on the lower end of the head. It's bit hard to see on the assembled engine:
And just as I'm typing this; another possibility could be a blown half-moon seal. This one is behind the plate the timing cover bolts on, and between engine & gearbox. And the speedo drive could be possible too.
I suggest you carefully and thoroughly clean the engine and watch where the oil is coming from - maybe thats an easyer approach than just fixing every possible seal. Which costs time and money. Try to locate the leak andthen fix it.
Cheers,
Jan
[edit] Bugger - this has been moved from mini chat to technical...
Edited by Asphalt, 21 March 2010 - 04:04 PM.
Posted 21 March 2010 - 04:45 PM
Posted 21 March 2010 - 08:58 PM
Posted 23 March 2010 - 11:01 PM
Posted 02 April 2010 - 03:28 PM
Posted 02 April 2010 - 10:45 PM
